Sponsored by: Wheel Design
Gear Ratio?
Old Jul 9, 2023 | 08:40 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default Gear Ratio?
What gear ratio does the base and Z51 have? And where in the Vin or build info can I find that information? Thank you!
Old Jul 9, 2023 | 09:09 AM
Fishfryer527's Avatar
Fishfryer527
I used google… “Chevy fits the Z51 with a shorter (numerically higher) final-drive ratio to improve acceleration. Base C8s get a 4.89:1 final-drive ratio, whereas Z51s are fitted with a 5.17.”
Not sure why they would bother with this small of a difference unless they were trying to optimize certain time to speed/distance times. Maybe they wanted another marketing line item for the Z51 package.
Old Jul 9, 2023 | 09:46 AM
Andybump's Avatar
Andybump
Old Jul 9, 2023 | 10:01 AM
cryptonic's Avatar
cryptonic
Be certain that we will not "feel" a miniscule 5% difference in gearing(not HP). Anyone who tells you that they can tell the difference of full of crap. There are still many guys who paid 5 grand more for this academic difference and believe that they have a faster car.
Old Jul 9, 2023 | 10:29 AM
Fishfryer527
5% increase in torque multiplication is substantial, but given the gearing, traction and electronic nannies I doubt we Z51ers can feel it.
Old Jul 9, 2023 | 11:31 AM
Mike's LS3's Avatar
Mike's LS3
As you can see in the above chart, the transmission gears and ring and pinion gears (not listed 3.55) are the same. However, on the Z51 the transfer gear is 1.46 vs 1.38 (non Z51) giving the Z51 higher numerical overall torque multiplication and final drive ratio (5.18 vs 4.89). The higher numerical Z51 transfer gears allow an advantage coming out of turns along with the E-differential. This might seem minimal, but with several laps on a track this improves overall time. Straight line performance is about .1 of a second faster for the Z51 which is a driver's race. I'm not going to make this a Z51 vs non Z51 discussion, just giving the facts. You decide what works best for you.
Your build sheet with the RPO codes will state Z51: Z51 performance package.
Old Jul 9, 2023 | 11:45 AM
mjhoward's Avatar
mjhoward
The final drive ratio isn't the only difference between a Z51 and non-Z51 car.
Old Jul 9, 2023 | 11:55 AM
Mike's LS3's Avatar
Mike's LS3
Yes, but the OP specifically asked about the gear ratio and build info. Let's not turn this thread into another comparison.
Old Jul 9, 2023 | 12:46 PM
JoeD-C8's Avatar
JoeD-C8
St. Jude Donor '18 thru '25
Apparently they did this to get under the magical 3.0 0-60 time.
Old Jul 9, 2023 | 01:51 PM
Cstansell2199's Avatar
Cstansell2199
2.9 does sound better 😂
Old Jul 9, 2023 | 06:20 PM
cryptonic's Avatar
cryptonic
And this is even better:
To Gear Ratio?
