Favorite Tools 2023
I am not sponsored or working for clicks but I wanted to share my favorites that I bought this year.
Ryobi had a buy a battery sale, get one tool for free, so I bought this LED light. If you have your car on jack stands and the wheels off, working on brakes or suspension, this is the best for aiming the light where you need it.
Not in your face, not casting shadows, this is the perfect height to direct the light exactly where you need it.
Hercules 3" polisher from HF. In the first few months I noticed several small scratches in the clear coat. I don't know if these came from the factory or car shows.
I tried hand polishing with Meguiars, it works but takes hours. This little buffer is easy to use and is just right for those small scratches. Just the right size.
Meguiars Quick Detailer. Love this stuff. Why take the car out of the garage and wash it just to get the dust off. A quick once over with this and you are ready to go to the car show.
What's on your list?
The are not gimmicky cheapo lights. They are very very bright, and will last a long time on its batteries. It is excellent for working under the a car, or on an engine, or just about anything. It also works well walking around at night. The light is always where you want it and your hands are free. If I need extra light I can place another one just about anywhere - because they are small.
I know exactly what you mean about orbital, that seems to be the number 1 choice these days. After watching a million polishing videos, I bought a 6" Kobalt dual action polisher.
Switching to the 6" seems like a monster. It is a lot heavier and harder to get the right feel. Whenever in doubt, I go back to the 3" because it is easier to control.
That's why it is my favorite, but I agree, a dual action is probably much safer.
I watch videos of pro detailer guys buff over edges with a dual action that I would never touch with the rotary.
Maybe that's why I am having a hard time adjusting to the Kobalt 6" dual action. It is a lot heavier, and I just don't have the feel I get with that lightweight 3" rotary.
With the dual action, it just does not have the disc speed since the pad is orbiting fast and not spinning as fast.
I would not want to use a 6" rotary, that could be dangerous, but the little 3" is pretty safe.
What do you use the deionized water for, how does that work. Where can I find out more. I know deionized water is the best for cleaning, but I know nothing about it.
I bought a battery blow dryer as part of the Ryobi deal. I have a pressure washer, need a foam cannon, and deion
A water deionized removes solids from the water. It's the solids left on the paint surface when the water evaporates that cause water spots. Left on the surface, water spots can etch the finish.
I connect my water deionizer, which is a Simple Chuck, between the hose and pressure washer for the final rinse. This guarantees the least amount of solids left on the paint surface and almost no water spots. Even when washing in direct sunlight.
Your battery-powered blow dryer probably does an adequate job of removing water from the car's cracks and crevices. The Master Blaster with two 4 HP electric motors does a fantastic job of removing water and speeds up the drying process. It also filters and heats the air it produces. I do 90% of the drying with my Master Blaster. The less I touch the paint the less chance there is to mar the finish.
Hope this answers your questions. Unfortunately, none of these tools are cheap.
My car is 6 months old has not been ceramic coated or anything except a coat of wax. I plan to use the 5" orbital to give it a good overall polish before the next car show in March.
I will probably use a Meguiars clay bar before polishing.
https://www.ebay.com/itm/164826557644
