I have one that I purchased for my 2005 Honda S2000 ,I purchased it from Costco .
I want to get one for my 2024 Corvette .
Which one do you recommend ? .
If the one you already have is a maintainer (and not just a trickle charger) and has a way to connect through the accessory port then I recommend that.
If you need a new one, a Die-hard from Wallyworld is only about $30 and comes with 3 different connections including one that fits the aux. plug in the frunk. No need to pay $60-100 for a 2 amp 12V maintainer.
Thank you ! Been orderec last night .
I was looking at it ,wasnt sure if its made for mine .
I was about to purchase one a genuine GM for $130
if this works I am fine with it .
Thanks for the info .
Get yourself the CTEK cigarette plug adapter: CTEK (56-870)
I direct wired mine to the battery with a Pigtail coming out under the hood by the wiper so that my hood stays closed completely all the time, plus with the pigtail wire on my driver's mirror it's hard to miss and forget vs coming out the passenger side. Just my choice.
