2024 C8 Maintenance - Table
Rotate Tires every 7,500
Oil & Filter every 7,500
Trans filter @ 7,500
Cabin Air filter 22,500 or every 24 months
Trans filter every 22,500
Trans fluid & Trans filter 45,000 (or every 3 years)
Spark plugs every 97,500
Hood lift struts @ 100,000
Cooling system 150,000 or every 6 years
Brake fluid every 5 years
Air conditioning desiccant every 7 years
Oil & Filter
Trans filter @ 7,500 (between 7000-8000 miles even it done earlier)
Trans filter every 22,500 (second change at 22,500 miles, then every 22,500 miles thereafter) or when the filter life monitor says so, or every 24 hours of track use.
Trans fluid & Trans filter 45,000 (or every 3 years), or when the fluid life monitor says so, or every 24 hours of track use.
A few questions for the forum: Is the maintenance schedule the same for years 2020 to 2024? I'm assuming the maintenance is the same for a 2024 as for my 2023, but we all know what happens when you assume things.
And haven't I read about a transmission fluid filter flush (not fluid change) that should be done with each oil change? I don't see it in the manual but I am certain I have read about it here.
Thanks, WishfulThinker23
The maintenance is the same in all the manuals. The 2024 manual clarified that the DCT filter change must be between 7000-8000 miles, regardless if done earlier. Previous manuals said "at 7500" without specifying a tolerance.
There is a somewhat minor change - The fluid change was always based on the fluid life monitor or 3 years. The later manuals added some wording that specifically said "at 45000 miles" - so it every three year, or at 45000 miles, or when the FLM says, or every 24 hours of use.
The lift struts is funny, I've never replaced them on a schedule. I replace them when they go bad. Possibly in there to clarify they are maintenance items and not covered under warranty after 100K miles.
It leads folks to another bad conclusion (as Andy pointed out in Post #2) where GM confounded the Engine Oil Filter change with the 7500 miles required to change the DCT filter. Makes folks think of the "Old Days" when miles and time were all we had. My two C7's and C6 ONLY SAID what it does in the C8 Owner's Manual if you look carefully ONLY the OLM is what determines when to change engine oil. Heck I knew GOOD Highway Miles were far far better than POOR City Miles from my Uncle in the mid 1950's. He was the Service Manager at a large Chevy dealer in a very big city on the East Coast (later was GM of the Dealership.)
I bought it with 4800 miles and a fresh oil change.
What should I request from the dealer for the 7500 mile maintenance
Many thanks.
This is my Invoice for my 2020 C8 end year 3 with ~8000 miles. Might bring it in as It's one of the lowest of those posted on the Forum. . If they want to charge a lot more, ask WHY!
Not it includes $106 for my engine Oil/Filter change as it was also due for change as all C8's regardless of low miles every 12 months minimum!
