Sponsored by: Wheel Design
Transmission question
Old Feb 16, 2024 | 07:25 PM
martybmw's Avatar
martybmw
Default Transmission question
I have a 22 C8 HTC Z51 and lately on occasion when somewhat spirited acceleration when backing off while in 2nd gear the it wont upshift or downshift just stays in 2nd. The trans stays in 2nd until I come to a complete stop and then drops back into 1st gear and this happens in sport, my mode and Z. Starting to happen more often so will be scheduling an appointment at my dealer and was wondering if anyone else has this issue.
thanks
Popular Reply
Feb 16, 2024, 08:55 PM
RKCRLR's Avatar
RKCRLR
You likely entered Performance Shift mode, it is described in the owner's manual. There is an indicator in the DIC when you enter the mode.
Old Feb 16, 2024 | 07:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Could be ok but tell more on car: miles, break in, service done on car, type of use (racing?), throwing any codes, any modifications, etc.
Old Feb 16, 2024 | 07:44 PM
CRUZ1NN's Avatar
CRUZ1NN
I am not a transmission expert but here is an article on the C8 Dual Clutch transmission: https://www.corvetteforum.com/articl...smissions-101/
The takeaway for me is this statement:
"A dual-clutch transmission, as you might expect, has two clutches. According to How Stuff Works, each clutch controls its own dedicated set of gears. In most cases, one clutch controls the odd gear numbers, while the second one fields the even gears. In simple terms, one can look at it as if it’s two manual transmissions operating side by side. The benefit here is that the next gear is always waiting and ready to go, so to speak, which results in blink-of-an-eye shifts. "
So how is the next gear already determined and ready to go? My opinion is that if you are accelerating in 2nd gear the DCT believes that the next gear is 3rd gear. If you decelerate quickly, the DCT has to either stay in 2nd gear or determine that the 3rd gear really needs to be 1st gear. Your speed may be too high to go back to 1st gear so it stays or hangs in 2nd gear.
This is my understanding and I am looking forward to others with a more physical and technical explanation so I increase my own knowledge.
Old Feb 16, 2024 | 08:46 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
MartyBMW, have you tested this situation while in 'Tour' mode.
Old Feb 16, 2024 | 08:55 PM
RKCRLR's Avatar
RKCRLR
Old Feb 17, 2024 | 07:07 AM
Undy's Avatar
Undy
From: Virginia Beach, VA & Port Charlotte, FL (snowbird)
A simple manual upshift will "cure" the OP's problem. Just tap your upshift paddle after you get off the gas. Sport or track modes create these situations, Completely normal.
Old Feb 17, 2024 | 08:51 AM
Andybump's Avatar
Andybump
thanks
Post 5 by RKCRLR is your most likely explanation. If you have downloaded a copy of the Owner Manual from the Chevrolet website. here
https://www.chevrolet.com/support/ve...manuals-guides
then you can search on these terms to read more about it, and decide if that is what you are experiencing:
"performance transmission", "performance shift", "driver influenced gear selection"
You will find the info is scattered in the manual which is why I suggest using the search. The manual does explain the feature, what triggers it, and how it will affect the shifting behavior.
Enjoy!
Old Feb 17, 2024 | 09:36 AM
proeagles's Avatar
proeagles
It's normal when you start driving "spirited", the car thinks you want to play so it stays in gear a little longer waiting for more throttle.
Old Feb 17, 2024 | 09:47 AM
Red C8 of Jax's Avatar
Red C8 of Jax
What proeagles says, he is 100% correct. Mine does the same. Completely normal.
To Transmission question
