Z Mode vs My Mode
Popular Reply
Z-mode and MyMode are both customizable Driver Modes, meaning you can select settings for features that affect the performance, ride, handling and sound of the car. The other modes default to specific settings.
In Z-mode, you can set Engine Sound, Steering, Suspension (if you have magride), Engine/Shift, Brake Feel, and you have access to the PTM setting if your car has PTM (Z-51 with magride). You don't get separate access to all the settings shown in the table in the manual (and in post 2) - the Transmission Shift, Throttle Progression, and AFM, are bundled into a single setting called Engine/Shift. Folks frequently comment about Z-mode as if was the racy mode etc., and it can be, but it can also be set up to exactly like the Weather Mode or Tour Mode if that is what you want.
With MyMode, you get the same options, with the exception of Engine/Shift, and access to PTM modes, which do not appear in that menu. In MyMode, the Engine/Shift setting is defaulted to Tour.
So the big difference is Z-mode allows you to select Engine/Shift settings and enables access to PTM modes, while in MyMode the Engine/Shift is set to Tour and cannot be changed, and you do not have access to PTM settings.
Anyone else with same?
1LT , non Z51
1LT , non Z51
Here's a chart you may find useful for the non-Z car.
Last edited by Andybump; Apr 8, 2024 at 11:47 AM. Reason: clarify this this the non-Z car.
It will go into 4th and stay in V4 MODE with easy acceleration.
I never noticed it out on the road with normal acceleration. Only in my neighborhood going slow looking out for the kiddies on our street.
Maybe check yours to see if it happens.
I do have a Soler Control set to SPORT 2. I guess I will check next drive to see if having it set to OEM makes any difference.
It shouldn’t, but🤔🤔.
