Climate controls. (Air conditioner)
thanks.
Manual says: Automatic Operation
The system automatically controls the fan
speed, air delivery, air conditioning, and
recirculation to heat or cool the vehicle to
the desired temperature.
When AUTO is pressed, all four functions
operate automatically. Each function can
also be manually set and the setting is
displayed. Functions not manually set will
continue to be automatically controlled,
even if the AUTO indicator is not lit.
A/C : Press to turn the air conditioning on
or off. An indicator light comes on to show
that the air conditioning is enabled. If the
fan is turned off, the air conditioner will not
run. The A/C light will stay on even if the
outside temperatures are below freezing.
If the A/C is turned off, the air temperature
coming through the climate control system
may be warmer than the ambient
temperature. It is recommended to use auto
climate control to maintain comfort.
Automatic Operation
The system automatically controls the fan speed, air delivery, air conditioning, and recirculation to heat or cool the vehicle to the desired temperature.
Air Delivery Mode Control : Press Y, [, or z to change the direction of the airflow.
Any combination of the three controls can be selected. An indicator light comes on in the selected mode button.
When AUTO is pressed, all four functions operate automatically. Each function can also be manually set and the setting is displayed. Functions not manually set will continue to be automatically controlled, even if the AUTO indicator is not lit.
thanks.
When you press Auto, either on the screen or on the row of buttons (doesn't matter), that should return all functions to automatic (fan speed, air conditioning compressor (A/C), as well as air delivery, and recirculation to heat/cool the car to the temp you have set. You should be able to set the temperature and go. The A/C button should be lit. If you touch any of the other controls, you own them. So if you adjust fan speed, then you own it. The purpose of the A/C button is to disable the air conditioning compressor. If you press it, then you own that feature. But if you press Auto again, it will return all settings to automatic control. If you are pressing Auto, and not seeing it light up the A/C button, then something is wrong.
I tested all of this before writing it. Pushing Auto returns all the features to auto. pushing A/C will disable the compressor. pushing auto again turns the compressor back on. Same with the fan speed.
As for temperature coming from the vents - for years and years - back to at least 1965 if not earlier, GM has designed their climate control systems so that the compressor is on almost all the time. All air flows over the A/C evaporator in the car, cooling and dehumidifying the air. Then a portion of the air flows over the heater core - and a portion does not - and the air mixed before exiting the into the cabin. The result is dehumidified air at the correct temperature. For a quick cool down, the air is not reheated, and the fan speed will be high. The air will be very cold coming out of the vents. As the cabin temp approaches the target temp, the air from the vents will not be as cold, and the fan speed will slow down. The system will regulate to maintain the desired cabin temp and keep the fan speed as low/quiet as it can be.
Some other design in the old days would just cycle the compressor on and off to regulate the temperature.
"Automatic Operation
When AUTO is pressed, all four functions operate automatically. Each function can also be manually set and the setting is displayed. Functions not manually set will continue to be automatically controlled, even if the AUTO indicator is not lit. For automatic operation:
1. Press AUTO.
2. Set the temperature. Allow the system
time to stabilize. Adjust the temperature
as needed for best comfort.
A/C : Press to turn the air conditioning on or off. An indicator light comes on to show that the air conditioning is enabled. If the fan is turned off, the air conditioner will not run. The A/C light will stay on even if the outside temperatures are below freezing. If the A/C is turned off, the air temperature coming through the climate control system may be warmer than the ambient temperature. It is recommended to use auto climate control to maintain comfort."
Most of this detail does not appear in the version of the Service Manual that I have, but here is a line from that manual that mentions the HVAC temperature door: "The amount of heat delivered to the passenger compartment is controlled by opening or closing the HVAC module air temperature door." I am familiar with the basic principles of this design having disassembled and repaired the Automatic Climate Control temperature control door in another GM vehicle.
While I was looking this up, I ran across something called a Front Floor Console Auxiliary Cooling (K4C). K4C is the code for the portable wireless device charger. Apparently that requires some cooling air. I attached an image showing the duct location. The complexity of this car has no end.
