z51 or not
https://gmauthority.com/blog/2021/06...h-z51-package/
https://gmauthority.com/blog/2022/07...g-z51-package/
will have a bit of coupling to add stability and
on-center steering feel. This will be a relatively
small amount (around 10% - 15%) and the number
will decrease slightly when making a lane change
or other steering input.
• When applying the throttle - The system will
increase the coupling under heavy throttle. The
driver may see around 40 - 50% coupling under
heavy acceleration in a track setting. This is to
maximize rear traction while cornering, while still
maintaining the feel of how the car handles
throughout the turn.
• Extreme lane changes and slalom events - The
largest coupling will occur during the most
aggressive dynamic maneuvers. The eLSD
clutches will nearly lock (100%) to add stability at
the right moment but open back up to allow the
vehicle to steer through a double lane change at
precisely the right times.
• Winter driving - If the vehicle is being driven in the
winter (being equipped with the appropriate tires),
and the driver is attempting to accelerate from a
stop with one wheel on ice and the other on dry
pavement, he or she will notice that the clutch
torque will increase on the DIC as a result of the
single wheel slipping. This will transfer torque to
the wheel with more available traction so that the
vehicle will accelerate smoothly.
https://static.nhtsa.gov/odi/tsbs/20...45400-0001.pdf
Bulletin No.: 19-NA-046 November, 2023 Page 3
This is a very short clip abstracted from the GM engineer, Jason Kolk's long forum post:
“There is a lot going on behind the scenes in the software to come up with the eLSD coupling that you can watch in C8 display. A number of algorithms that are running at the same time to collectively decide how much coupling is needed for the different vehicle dynamics situations that they each monitor and control. Logic is used to decide which one of them wins out or which ones add together to deliver the final command that you see on the display and feel in the car.” “The eLSD can have subtle but profound effect on handling of the c8. It’s considered a ‘basic chassis’ component. It something that plays a big part in setting up the character of the car. Off-throttle, more eLSD coupling adds stability, but too much can be a bad thing. The eLSD is connecting the two wheels so in a turn it's trying to slow down the outside wheel and speed up the inside wheel. In other words, the eLSD clutch coupling is trying to oppose the direction that the car is turning, so setting this off-throttle level is pretty important to keeping the car feeling agile. In a steady turn this can help tune the amount of understeer the car has. In highly dynamic maneuvers, this results in something that we call yaw damping where it will reduce the rotation rate of the car. When the driver is on-throttle, the eLSD clutch can shift torque from the inside wheel to the outside wheel. This has the combined effect of minimizing or eliminating inside wheel spin, but it also controls how much it feels like the car turns with the throttle. More torque on the outside and less on the inside will help the car turn - to a point, but that's the balance we're constantly searching for while we tune the software.
You can read his and Tadge Juechter's "Ask Tadge" forum post in full in the Appendix of my Doc with a many Pic summary up front. http://netwelding.com/eLSD_VS_Posi.pdf
The Appendix also includes several Videos including one by an automotive Professor who shows what the 1960's Positraction included with the Base C8 is limited to do. The eLSD does much more. In my E-Ray it is providing in the rear what Torque Vectoring is to the front wheels when accelerating from an apex.
Yep I see the % slip change when going almost straight as I apply power etc.
My suggestion is always plan your budget and get the most you can or desire for the money. The C8 is amazing as to how it can be configured. Decide which options are drop dead and you can't do without and go from there. In my case HTC was the only real drop dead, the rest became what was in my budget.
This. Extra option packages (Z51) are going to depreciate at the same rate as the car, sometimes more. You're never going to make your money back by adding options, if you're worried about resale vs loss, you're best off buying a 1LT stripper. Dealers could care less about options on trade, they are just going from a book wholesale value, and while some private party sales will want Z51, plenty of people could care less and just want the best deal.
I ran a 2022 red 2LT, 12,000 miles, good condition with Z51, no other options, and without Z51, no other options.
Looks like around $300 difference, same to same. I believe Z51 cost $6,345 in 2022.
Maybe it sells faster with Z51 since it is essentially "free" at resale?
If it came with all-seasons and non-dust brake pads, I'd have bought it but I didn't want to replace all that with winter a month away from delivery.
"Specifiers" order their vehicle or scour listings to find the very closest match to their ideal vehicle.
"Selectors" look at what is available and pick one. I think most used car dealers by default are "Selectors" out of necessity. I think the typical* buyer of a 2+ year old C8 is looking for a price, milage/condition, roof option and color that they like and look no further than that.
(*The next 20 people to talk about how they specified intensely for their used purpose, you are on an enthusiast forum so not typical!)
I like to slide the car around and intentionally break traction. When I have done this in Z-51 equipped cars I can feel the diff trying to straighten me out when I want to try and hold the angle. When I do it in my non Z51 with the mechanical diff it just keeps both wheels spinning but isn't cutting power the same to manage traction.
The other thing for me is predictability when randomly getting near limit. The E-LSD will respond differently based on the mode you are in and how all the sensors feel about that specific slide. The mechanical diff with traction off is the same in weather or track.
I will add, no I am not in traffic drifting the car. I do autocross and at low speeds rotation is helpful unlike a sweeper at 90MPH on a full track. I also have some friends that own industrial warehouses so we have access to the back loading dock area for BBQ and burnouts, etc.
To each their own, I know the mechanical LSD is slower but can be more fun!
