Time / Date Use the following features to set the clock: . Automatic Time and Date: Touch Off or On to enable or disable automatic update of the time and date. When this feature is on, the time and date cannot be manually set. . Set Time: Touch to manually set the time using the controls on the infotainment display. . Set Date: Touch to manually set the date using the controls on the infotainment display. . Automatic Time Zone (If Equipped): Touch Off or On to disable or enable automatic update of the time zone based on vehicle location. When this feature is on, the time zone cannot be manually set. . Select Time Zone: Touch to manually set the time zone. Select a time zone from the list. . 24-hour Format: Touch to specify the clock format shown. Touch Off or On to disable or enable.
I picked up my 2025 C8 HTC on Wednesday of last week, as in four days before the time change. I was pleasantly surprised when I got into the car on Sunday that the clock has already been reset.
