Sponsored by: Wheel Design
TPS..2024 to 2025 Compatable?
Old Apr 2, 2025 | 05:33 PM
My13thVette's Avatar
My13thVette
Default TPS..2024 to 2025 Compatable?
Can anyone tell me if the TPS on a 25 Stingray match the 24s? I am in the process of buying a set of take offs from a 2025 for my 2024. Does the reprogramming have to be done at a dealer?
Thanks in advance.
Old Apr 2, 2025 | 06:23 PM
sjw91's Avatar
sjw91
Thanks in advance.
Do you mean Tire Pressure Sensors? They are self-learning, but require about 10 miles of driving before they're set.
Old Apr 2, 2025 | 06:39 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Thanks for trying to guess what TPS is!! Not very good to ask a question and with all the acronyms that was not my 1st thought!
If that is it, looks like your answer would explain to the OP!
Old Apr 2, 2025 | 07:19 PM
EC145Pilot's Avatar
EC145Pilot
They are compatible and you can use a TPMS programming tool to reset them.
Just do a search for EL-50448 TPMS relearn tool. Very inexpensive.
TPMS relearn tool TPMS relearn tool
Old Apr 2, 2025 | 07:53 PM
sjw91's Avatar
sjw91
Tool isn't necessary. From the owners manual:
Old Apr 2, 2025 | 08:56 PM
Mark9's Avatar
Mark9
There is a relearn option within the DIC. Doesn't take long for the relearn to happen when using it.
Old Apr 3, 2025 | 12:59 AM
Bald Guy's Avatar
Bald Guy
Looks like you found plentiful of good answers and I'm just adding to my post count here. So good luck on finding out and let us know if it recalibrates successfully after 10 minutes or 10 miles so that others know as well.
Old Apr 3, 2025 | 10:02 PM
BandDirector's Avatar
BandDirector
Did you get the memo? Yeah…uh…I’m gonna need you to use the new cover sheet on your TPS reports…
Old Apr 7, 2025 | 11:20 AM
MKK1's Avatar
MKK1
Thanks in advance.
If you are trying to use the old ones, I think that sometimes they can get damaged upon removal and may not work well. For a few bucks more, I would recommend buying new ones. Usually they are pre-programmed for your car depending on where you get them. This way you know that the reading is accurate.
Old Apr 8, 2025 | 09:46 AM
Cjunkie's Avatar
Cjunkie
Thanks in advance.
There are TWO different part numbers for wheel sensors on C8 wheels. To find out which one you have you need to pull the build codes for YOUR car. The two codes are XL7 and XL8 and each has a different GM part number. You need the code from the car the wheels came off of and see if they match your car.
Now I have no clue what the differences are maybe frequencies? Are they interchangeable, maybe I don’t know. Can you program a different one to your car I don’t know.
Old Apr 8, 2025 | 02:46 PM
BandDirector
I run a set of CF take-offs from a '21 on my '24 with NO TPMS reading problems...
To TPS..2024 to 2025 Compatable?
