Sponsored by: Wheel Design
Simple snapped cable end repair for C8 convertible
Old May 28, 2025 | 08:10 AM
Huizy's Avatar
Huizy
Dude
Default Simple snapped cable end repair for C8 convertible
A simple repair of the folding trim cable that snaps off of the retainer.
Open top halfway and hold trim down with zuptie.
Pull cables to max length
Remove the broken cable token, the little round piece that the cable snapped out of
Install medium washer over end of cable.
Install smaller washer over end of cable.
Put small C clip into pliers and crimp C clip close to the button at the end of the cable.
Reinsert cable into slot on tension box.
Cut zip tie.
That's it. You can use the top until your dealer gets you a new cable...or save the 300 to buy it.
Old May 28, 2025 | 08:25 AM
steve8's Avatar
steve8
Thank you!
Copied this for future reference if needed.
Old May 28, 2025 | 08:52 AM
CAB6's Avatar
CAB6
2025 c8 of the Year Finalist - Modified
2023 C8 of the Year Finalist - Modified
2022 C8 of the Year Finalist - Unmodified
2021 Corvette of the Year - Unmodified
2020 C7 of the Year Winner - Unmodified
Does anyone know how to adjust the head rest pieces so they both move at the same time? Mine are off a little bit. One starts a little later.
Old May 28, 2025 | 09:18 AM
cmck0916's Avatar
cmck0916
Love this thread, thanks for posting, OP!
If outside of warranty, I presume one could also crimp on a permanent ferrule on the end of the cable? No way I would ever pay $300 for a simple cable.
Old May 28, 2025 | 09:25 AM
brian98vette's Avatar
brian98vette
Having just had this repaired (under warranty) they replace the whole bracket, not just the cable (or they did in my case anyway) which is probably why it’s so expensive. Thanks OP for the post!
Old May 28, 2025 | 09:28 AM
op z's Avatar
op z
Great solution. Maybe install two C clips on the end with one rotated 180 degrees. It seems like that would be less likely to pull out.
Old May 28, 2025 | 12:22 PM
Huizy's Avatar
Huizy
Dude
MKe sure both ferrels are in the cam wheel at the top near the trim price. They slide off.
Old May 28, 2025 | 12:24 PM
Huizy's Avatar
Huizy
Dude
That would work. The little token the cable sits in is junk. I'm sure the other side will snap soon. Lol
Old May 28, 2025 | 12:25 PM
Huizy's Avatar
Huizy
Dude
It would be better
It's a 5 MN repair either way.
Old May 28, 2025 | 01:36 PM
Red Mist Rulz's Avatar
Red Mist Rulz
If the swaged fitting on the factory assembly doesn't hold, I have my doubts a c-clip is going to last very long either. But it's worth a try given how expensive the replacement part is.
Old May 28, 2025 | 02:02 PM
Huizy's Avatar
Huizy
Dude
The factory assembly is a tiny token with a hole drilled halfway through and they soldered or melted the end of the cable into it. I can see where the thin outer edge of the opening just broke. I could add a dab of solder to the cable to fatten it up. Or, take a SS washer, ID same as cable OD, cut a slice into the washer, insert and crimp? Then solder the whole thing together?
I use C clips on 5th scale RC cars all the time. They hold pretty well.
Old May 28, 2025 | 02:05 PM
Huizy's Avatar
Huizy
Dude
Old fitting. The cable end is "soldered" into this hole
Old May 28, 2025 | 03:03 PM
Drewbzmn's Avatar
Drewbzmn
Ingenious.
Old May 29, 2025 | 03:23 PM
Red Mist Rulz
I'm surprised. I would have bet the fitting was swaged. That's a really cheap-*** way of building it.
Old May 29, 2025 | 03:47 PM
Prowlen99's Avatar
Prowlen99
How do you think these things have gotten so expensive ... oh, wait .. cheap azz parts paying WAY too much for and then passing along the over charging to us the consumers ... GM ... amazing
Old May 29, 2025 | 04:23 PM
RKCRLR's Avatar
RKCRLR
I believe the ferrule is actually cast in place. The reason it fails might because of poor quality control on the heat applied during the casting process causing a brittle heat affected zone on the cable.
Old May 29, 2025 | 04:54 PM
oldboomer54's Avatar
oldboomer54
Any home repair would be equal to, or better, than the original construction. If it happens to me, I'll simply braze a washer onto the cable.
To Simple snapped cable end repair for C8 convertible
Old May 29, 2025 | 11:26 PM
OP - thanks for posting up your solution for the cable repair. Surely will come in handy for other C8 HTC members.
Old May 30, 2025 | 08:15 AM
Slare's Avatar
Slare
OP's method with a ball of JB weld encapsulating the fix would last until the actual cable snaps. You just need to have enough of the cable to form a knot the weld can hold on to. If I ever have this issue out of warranty that'd be my attack plan.
Old May 30, 2025 | 08:56 AM
utownal's Avatar
utownal
As an HTC owner, Thanks for the information.
