Sponsored by: Wheel Design
5VM style rockers
Old Aug 9, 2025 | 04:59 PM
gxtol@yahoo.com's Avatar
gxtol@yahoo.com
6th Gear
Default 5VM style rockers
Can 5VM style rockers and front spitters be removed without damaging the vehicle? I’m considering a 2024 convertible with these items already installed. Not a fan and want them removed.
Old Aug 9, 2025 | 05:42 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Yes the splitter can be removed without damage. The skirt might leave a drill hole at the rear fin area in the panel. You should be able to see in there if it does. If not that can be removed without damage too.
Old Aug 9, 2025 | 06:40 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
[[img]https://i.postimg.cc/tCtMHVk1/IMG_1327.jpg
IF they are the 5VM OEM carbon fiber the side skirts required a large hole to be drilled in the rear fender.
My How To Doc covers the GM install and shows where it is drilled: http://netwelding.com/Side_Skirts.pdf
This Pic from my Doc may help. It's the GM OEM side skirt install procedure. You'll see in step 3 the hole being drilled in the fender for a bolt that hold the winglet. In Pic 6 you'll see the bolt being tighten from the back of the fender to 22 ft-lbs. If aftermarket probably does not have that drilled hole. The rivets under the side skirt go into the bottom of the ricker panel Only an ant would see the small holes when removed. Probably have to drill them out. The OEM carbon fiber side skirts were very thin and also used 3M tape and what will be very difficult to remove a 3M adhesive used to install windows. I dealt with that window adhesive when I installed windows in my '34 Ford my street rod, strong tough stuff! If it was used (as GM procedure called for ) good chance paint will come with it!
Yep splitter is easy bolted on with OEM bolts that you'll just reinstall when it's off.
Old Aug 9, 2025 | 08:37 PM
Avanti's Avatar
Avanti
You might wish to see what a good body-shop can do with the side skirts.
Old Aug 9, 2025 | 08:50 PM
bpk1959's Avatar
bpk1959
I have 1vm and would love to have the 5vm. if you buy the car ill trade with you and cover the shipping
Old Aug 10, 2025 | 07:20 PM
gxtol@yahoo.com
6th Gear
Thanks for the responses. Just curious, I am pretty old…does anyone else think these look good?
Old Aug 10, 2025 | 07:36 PM
bpk1959's Avatar
bpk1959
im 67 and I think 5vm is perfect
Old Aug 10, 2025 | 07:37 PM
DrivesWithTwoFeet
I don't care for the look of the 5VM style but it is very popular.
Old Aug 11, 2025 | 12:10 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
I put 5VM side skirts and splitter on my '22 C8 right after it was delivered new. I still have 5VM's (a replacement in the case of the splitter) and still think they look good. BTW, I'm 75 years old.
Old Aug 11, 2025 | 07:06 AM
JerryU's Avatar
JerryU
Hmm, at 82 I think form follows function and in our rural area they stop rocks hitting and dinging the rocker panels and in front of the rear wheel wells.
Here are some Pics:
After my 1st two Vettes, C4s looked new when I sold them except for dings in the rocker panels and after the rear wheel I installed these large splash guards on my new C6. Although contoured and body color were a bit gorpy! The Rears worked but the Fronts did NOT stop pebbles thrown by the front tires from dinging the rockers near the rear wheel well.
GM knew where the problem was and added clear plastic film from the center of my C7 2014 Z51 doors up to the front of the rear wheel well. BUT they used clear, thick plastic, easier to install and it was dinged within a month and looked bad. I added full length side skirts that solved the problem. Removed their cheap, marked PPF. Also added full length side skirts to my 2017 Grand Sport.
This is a Pic a fellow took of his C8 after Tracking. This is where the Rubber on the Track hits. And no shape front splash guards no matter how deep and wide (like I added to my C6) will stop pebbles throw by the front tires hit in the back area!
So for me Form Follows Function! Therefore I think the side skirts I added to stop pebble dings LOOK GREAT!
Some think the Winglets were added to look good! NOT! Just as used on most Jet Planes today they make the side skirts (and front splitter) technical function of providing downforce, more effective. Now at normal street driving speeds not needed. But at 150 mph they help add downforce. And just like airplanes the winglets prevent high pressure on one side from spilling over the edge to low pressure reducing effectiveness. On airplanes they improve the wings effectiveness providing 3 to 4% better fuel economy! Understanding their function I think they look fine! Again Form Follows Function even for this 82 year old!
Old Aug 11, 2025 | 08:34 AM
snork's Avatar
snork
side skirts are the cheep 5vm wanta-be and easily removed without the side panel fastener
if you can get $5 for any of that crap sell it otherwise landfill is its destination
To 5VM style rockers
