Considering C8 Z51 purchase
I added my 21 Z51 3LT about a month ago. Oil changes look to be as easy if not easier than the C5. Air filter is buried on the C8 but not hard to replace. Trans filter looks to be a pretty simple change. It’s just a car with bolts like any other.
Warranty is what it is. Don’t limit yourself by only looking at cars you can get GM extended coverage. If the things are that susceptible to failure, I wouldnt even buy one. For the most part I think it’s just people afraid of new technology and stories they’ve heard about. My 21 only had 1400 miles so I couldn’t get the Platinum extended coverage. The dealer adds 5 year powertrain coverage on all the vehicles they sale. I’m gonna maintain it like the book says and if I happen to have an issue, it’ll get towed to the dealer.
I already used the Lemon Law process to return a C8 that was never repaired correctly, have no problems doing it again.
I do respect those that have the skills, tools and knowledge to do maintenance work themselves, however I get a bit frustrated sometimes when some ignorant clown tells me I am not a true auto enthusiast because I don't "work" on my cars.
Don't like ramps, one always moved with my C6 as I drove up on them. So gave mine to a friend who needed to lift on grass! Below are some Pics on my changing oil on a C7. IF I had not found a great C8 Trained Tech at a small dealer ~30 miles from my home I would be doing myself. However the DCT requires a Flush prior to the DCT filter change. It's done by the GM Service Computer. Looks like now you can buy a device that works to do it! Could not initially so I looked to find a Dealer Tech I trussed. I have and let him do everything.
PS: The GM issue with the LT2 is with Trucks that use a different crank. This issue was blamed on crack tolerance. None issue with Vette. Same with lifters not a significant issue with Vette's in some minds BUT no evidence. I had V8/V4 in two C7s, in my 2020 C8 Z51 and now E-Ray. IMO a none issue. It is totally transparent when I use MY Mode. Don't hear or feel anything, Some do BUT I and many others do not.
My C7 like my C6 needed to be level when changing oil to drain most oil.
I follow the advise of a Warning on a pair of jack stands I have what say "Only Use On One End of the Car At A Time." Safer to Use Wheel Stanchions On One End.
I spent over a month on my shop floor crawler when i built my street rod. Worth the two step jacking that required to get up on my commercial 12 inch high wheel Stanchions. Sill have them BUT PIA to jack that high. The 8" high I suggest are high enough to jack the C8 for oil changes and should be OK to remove the rear aero panel shear plate. to make a DCT filter change AND fluid change.
With the C8 drain plug in the front of the engine just lifting the rear will get most oil out. The 8" stanchions I suggest or the commercial 10 inch high from race ramps will work. I would use two jacks in GM oval jack lifts with jack pads and jack evenly.
When C8 came around I was all in. Two years later, no regrets. I love my C8 and would never consider going back to a C6 or C7.
I am a DIY guy also. No worries about maintenance. Yes, the car is way more complex that previous years, so what. That makes it interesting.
There have been many posts about jacking up the car. One side a time, no problem.
There is a spot front and back where you put the jack stand. That is not where you put the jack.
The jack goes in basically at the back of the door, then the car raises front and back wheels equally.
Then put the jack stands in the right spots. One side up on jack stands; take the jack to the other side; repeat the lift for side two.
Jacking from front or back looks near impossible to me. Using two jacks totally unnecessary.
I have had the under engine panel off two times to find dropped tools. It's no big deal.
2. DCT external canister filter - must be changed between 7000-8000 miles even if done earlier, then 22,500 miles, then every 22,500 miles after. GM is very picky about this, having sent reminder letters to most all owners about it. And it does apply all the way back to 2020.
3. Transmission Fluid - change it when the fluid life system says so, or every 45000 miles, or at least every three years, whichever is first. Again, GM is picky about this.
Here is some language from the Warranty Manual:
"As the vehicle owner, you are responsible
for the performance of the scheduled
maintenance listed in your Owner’s Manual.
GM recommends that you retain all
maintenance receipts for your vehicle,
but GM cannot deny warranty coverage
solely for the lack of receipts or for your
failure to ensure the performance of all
scheduled maintenance."
However GM can deny coverage if damage is cause by lack of maintenance:
"Damage caused by failure to follow
the recommended maintenance schedule
intervals and/or failure to use or
maintain proper fluids, lubricants, or
refrigerants between maintenance intervals
recommended in the Owner's Manual is
not covered. Vehicle"
And here is the language about receipts:
"Retain receipts covering performance of
regular maintenance. Receipts can be
especially important if a question arises as
to whether a malfunction is caused by lack
of maintenance or a defect in material or
workmanship. These receipts and records
should be transferred to each subsequent
owner of this vehicle.
A “Maintenance Record" is provided in the
maintenance schedule section of the Owner's
Manual for recording services performed.
The servicing dealer should provide a copy of
any warranty repairs for your records."
Ok?
Ok?
Fortunately, after driving the car for 10 miles or so, the code cleared itself.
So if I changed the DCT filter at 7500 miles, then at 15000 mile the transmission takes a dump, I wouldn't be surprised if they tried to void the warranty. I guess that's what lawyers are for.
And another thing. The manual actually gives instruction for disconnecting the battery to service the brakes. I do no know why, but it also says do not disconnect the battery during storage.
Techs and service writers are not always the best communicators - and they may have mean that they need to diagnose the problem before deciding how to proceed, and if the issue was caused by the battery being disconnected, it may not be covered under warranty. But...it does not seem possible that disconnecting the battery caused any damage. If you like the dealer you might have a discussion about what they really meant. There's really no advantage for them to be avoid a valid warranty repair. But still there are reports of exactly that from time to time .....
- Engine oil/filter
- All DCT Fluid
- DCT filter with GM specified flush (that took about 15 minutes this time versus only 10 minutes year one when I had ~3000 miles and it was done on GM's Dime.) Took ~5 minutes for Tech to connect to GM Service Computer that actually does all the work! Must have been a buzzy day!
- Granted it was in August 2023 but I'd bring a copy of my bill and ask why so much?
