Reset oil change counter ?
How to Reset the Engine Oil Life System Reset the system whenever the engine oil is changed so that the system can calculate the next engine oil change. To reset the system: 1. Scroll through the DIC Info Pages menu until the REMAINING OIL LIFE percentage is displayed. See Driver Information Center (DIC) 0 108. 2. Press and hold SEL on the DIC while the Oil Life display is active. The oil life will change to 100%.
To reset the C8 Corvette's oil change light,
turn the ignition to the "on" position, navigate to the "Maintenance" menu using the right-side steering wheel thumb wheel, and select "Engine Oil Life." Highlight "Reset" and select "Yes" to confirm the reset. The display will then show 100% oil life.
You wasted more time creating a new thread, just google: c8 corvette oil change reset.
Like "How do you tell if a vampire is sick? By his coffin."
But anyway - respectfully - if its a serious question its on page 246 of your 2023 manual:
