DCT fluid change
Its a salesman trick.....Your'e spending 100,000 on this, and you can't even come up with a extra 1000 dollars for blah blah whatever. The buyers response is, if 1000 is so piddling, just just take it out of your pocket and hand to me, and we have a deal.
The majority of folks discussing the use of alternative fluids are DIYers - and most are probably well off, with new C8, probably a couple of other daily drivers, a place to keep them, a shop to work on them, and very likely a healthy retirement account or other investments. They.re not likely to accept the suggestion that they are just being cheap. They are doing it themselves not just to save money (which it does by an enormous amount) - it s hobby for many - and many do not want the dealer tech to touch their car. That is their choice. And if you are doing it yourself, you don't have to pay the retail price for the Delco fluid that most dealers charge. You can find it at considerably lower price if that is what you want to use. If their motivation is to save money, so what? That why they have all that stuff.
Consider some DCT's by say Porsche that uses separate fluids for the clutches and gears. That allows a lower viscosity different composition fluid for the multiplate clutches and higher viscosity gears. Tremec uses ONE fluid for both. It's a relatively low viscosity fluid similar to that used by slushbox automatics. No doubt needed for a key feature for clutches, keeping them cool as they slip on engagement. For gears there are many additives used to compensate for the low viscosity fluid to handle higher loads, like extreme pressure lubricants, shear stability, friction modifiers, antioxidants, anti-wear agents, detergents/dispersants etc. One many page technical source I found stated up to 20% of the fluid can be additives and some expensive.
With a 2021 your close to being past the GM warranty. IF the DCT needs replacement currently that is a $20,000 bill for a new one. Heck, I self insure myself for many things BUT for $20,000, I'd buy the GM specified fluid, cheap insurance for at least while you still have some GM warranty left. If doing yourself see some on the Internet from a trusted source for $33/Liter.
Just learned today, my fault/ignorance I guess, that the DCT fluid needs to be changed out. I 'thought' that I had until 8K miles to be thinking about it but just learned that at 3 years no matter what, the fluid needs to be changed. Well, I have a 2023 and it's now 2026. Admittedly don't know when the vehicle was first sold and on the road.
They will change out the filter too.....but learned also that at 8K miles the filter to be done again no matter I've done it now at under 5K.
I just don't remember having these deadlines in my previous Vettes........but can't blame anyone except myself
So anyway, the question is about mixing the Motul High Torque DCTF with residual OEM fluid in the transmission when changing the fluid. Here is a product data sheet of sorts for that Motul Product:
https://azupim01.motul.com/media/mot...5_20220505.pdf
This data sheet says 100% Synthetic - ESTER. So, ostensibly, it would contain nothing distilled from crude oil. Its Safety Data Sheet says it contains 1-Decene, trimer, hydrogenated in proportion between 50-100%.
https://d347awuzx0kdse.cloudfront.ne...0617f11f038705
I beleive this compound is considered a polyalphaolefin which is a lab engineered hydrocarbon. The SDS also mentions Distillates (petroleum), hydrotreated heavy paraffinic in proportion between 2.5 and 10%. And it lists Lubricating oils (petroleum), C15-30, hydrotreated neutral oil-based in proportion between 1 and 2.5%. So I would say it is primarily lab engineered and manufactured synthetic oil, with a small amount of petroleum distillates mixed in.
As I noted in post 50, ACDelco is a blend of PAOs and petroleum distillates as well, based on its SDS.
Can you mix them? The PDS for Motul says this, about that: "Can be mixed only with similar quality lubricants"
I'm thinking they are similar quality lubricants and can be mixed, but that just opinion. The PDS does say that the MOTUL product is suitable for use where Pentosin FFL-4 is called for but that is not the same as saying they can be mixed. Pentosin FFL-4 is also the same as Titan FFL-4 and ACDelco DCTF FFL-4.
Its hard to find a complete PDS for the ACDelco product, but if you accept that it is the same as the Fuchs Titan FFL-4 (which I do), there is a PDS for that, and it says " To warrant the perfect functions of the transmission, TITAN FFL-4 must not be blended with any other transmission oils under any circumstances."
https://www.fuchs-lubricants.ro/user...AN%20FFL-4.pdf
So use your own judgment. Folks have mixed Valvoline and residual OEM fluid with no issues.
Has anyone noticed any change in performance or DCT feel as a result of using Valvoline?
And have most people performed a drain and fill? I guess the other option is to do a flush and that would ensure that there isn’t any fluid mixing
https://gm-techlink.com/?p=12881
The PDS is the manufacturers advertisement sheet where they share what they wish about the product, including recommendations, and the Safety Data Sheet (SDS) which is a government required form and must list ingredients that the EPA thinks may potentially be hazardous. And, you're right - neither one is a perfect way to establish equivalence, unless they mention a recognized specification, such as "meets dexos R". In absence of that, we must guess or accept the manufacturer's statements about applications.
We have no specification for the DCTF that the C8 requires, only product recommendations, and those usually appear in the PDS, or the manufacturers product finder. So when choosing an alternative product, you are relying on the manufacturers reputation and recommendation - and your trust in that.
And similarly, you can't use an SDS to establish equivalence either. They list only ingredients requires by law that are potentially hazardous, and do not list the exact proportions, and I have never seen them mention a product specification. They are useful for determining some of what is in there, but useless for determining equivalence.
Hopefully the fluid manufacturers did their job when recommending their fluid and there aren't any long term effects of using non-ACDelco/Fuchs FFL-4 fluid in a C8 DCT.
https://www.hotcars.com/emelia-hartf...tul-dct-fluid/
The article discusses, at a high level, some of what was involved in the development of the MOTUL formulation, which included a comparison of the MOTUL fluid and the OEM fluid after use. This sentence stuck out for me, where it is discussing this comparison:
"Motul then tested the breakdown levels of the oil and additives in those samples, trying to find the ideal balance between the car's real-world performance and protecting the transaxle's internal components."
Sounds like a trade off between high performance and protection of the transmission components. The article really does not elaborate on the details of the tradeoffs though.
The product data sheet for this MOTUL promises to deliver on everything - it give "superior transmission response" and "Increased anti wear protection" (not even a hint that there may be a trade-off):
Provides perfect friction level suited to high torque/power engines for transferring maximum power to the wheels.
- Gives superior transmission response: smooth shift feeling and no torque interruption in-between shifts.
- Improves DCT transmissions flexibility and response at cold and high temperature.
- Keeps consistent viscosity even at extreme temperatures to provide the best protection for all DCT components.
- Provides anti-shudder performance to avoid vibrations on engine flywheel.
- Protects numerous gears, compact and heavily loaded.
- Extends lifetime duration, superior shear stability at high temperature.
- Offers significantly better oxidation resistance than conventional synthetic product.
- Increased anti-wear protection, higher anti-corrosion and anti-foam performance
