Sponsored by: Wheel Design
Ceramic coaring
Old Apr 2, 2026 | 08:25 PM
TheBigDog's Avatar
TheBigDog
Default Ceramic coaring
My Sebring Orange C8 has been ceramic coated now for three years. Just wondering is there a way to enhance the shine and make it brighter. I was told by my body man that a spray on ceramic wax would do the trick. Then wipe down with a microfiber towel. Is he correct
Old Apr 2, 2026 | 08:32 PM
RedZed51's Avatar
RedZed51
Yes, take a look at some of the spray on products. Most companies make them now. For example: Griot's Garage 3 in 1 ceramic spray wax.
Old Apr 2, 2026 | 08:42 PM
ahalachis's Avatar
ahalachis
Are you saying that it has got less “bright” over the past three years….if so there are so many factors that come into play with how nice and how long a ceramic coating will last, the first and most important is the curing period after it is first applied and what was followed. Below is a good link that goes into detail. I would take it back to whoever did the initial application...
https://www.rightchoicemobiledetaili...eramic-coating
Old Apr 2, 2026 | 08:45 PM
C5racecar's Avatar
C5racecar
Turtle Wax Hybrid Ceramic. Low cost, available anywhere. Easy to apply once a year.
I can wax the whole car in less than an hour.
Old Apr 2, 2026 | 09:00 PM
mtraylor2001's Avatar
mtraylor2001
You can use any topper that you want. I suggest you decontaminate the surface first. I would do the following.
1. Spray the car down with ironx. Get off all the brake dust etc off. Spray the body of the car including the wheels and barrels. Follow instructions.
Adam's Iron Remover Gallon with Free 16oz
2. Wash car with a good foaming cleaning soap such as carpro reset
Amazon.com: CARPRO Reset - Intensive Car Wash Shampoo Perfect for Ceramic Coating & Nanotechnology Based Sealants and Coatings, pH-Neutral - 500mL (17oz) : Beauty & Personal Care Amazon.com: CARPRO Reset - Intensive Car Wash Shampoo Perfect for Ceramic Coating & Nanotechnology Based Sealants and Coatings, pH-Neutral - 500mL (17oz) : Beauty & Personal Care
3. After wash spray with your favorite topper.
Amazon.com: XPEL Ceramic Boost Spray Coating, 16oz - Silicon Dioxide Car Detailing Spray, Beads and Repels Water, Dust, Lint, and Protects Against Debris - Safe for Cars, Trucks, Motorcycles, RV's & More : Everything Else Amazon.com: XPEL Ceramic Boost Spray Coating, 16oz - Silicon Dioxide Car Detailing Spray, Beads and Repels Water, Dust, Lint, and Protects Against Debris - Safe for Cars, Trucks, Motorcycles, RV's & More : Everything Else
You can use the topper after every wash if you like to enhance the silicon and shine. I usually spray mine with my own homemade topper.
Good luck.
Old Apr 2, 2026 | 09:49 PM
Red Sleeper's Avatar
Red Sleeper
I tried this and found it very easy to use so I ordered two bottles since it was on sale. I have applied it to my red C8 and was sort of pleased but it didn't seem that shiny or that slick. My old favorite wax was Meguiars Ultimate-Liquid-Wax so I did a comparison by waxing half the top the with ceramic and the other with Meguiars Ultimate. Meguiars was slicker and in my opinion possibly had a better shine.
Also, do not apply the Turtle wax ceramic to the inside of your windshield b/c it will after a few days cloud over.
Old Apr 2, 2026 | 10:00 PM
Smokinlmm's Avatar
Smokinlmm
Use “The Last Coat”, it is sold on EBay and Amazon. Best stuff for the value. Wash the car with a good PH balanced soap and add about an ounce of Isopropyl Alcohol to the mix. The alcohol helps to remove the oils and wax so the ceramic can stick and fill the voids. I have used The
Last Coat for years on everything I own, boats, cars, trucks, etc. It really works well and lasts for at least 6 months out in the weather, longer if stored inside.
Old Apr 2, 2026 | 10:32 PM
cmonkey713's Avatar
cmonkey713
Contact Esoteric Detailing and describe your situation. They are a very high-end detailing house with a wide range of specialized products they can recommend. These guys are very good at what they do. I have used them for several years.
Old Apr 3, 2026 | 05:21 AM
SpeedyATL's Avatar
SpeedyATL
Most of the major ceramic brands offer a "boost" product. Just buy the one from your ceramic brand and follow the instructions and apply it once every 3 to 6 months.
Old Apr 3, 2026 | 05:59 AM
M&N's Avatar
M&N
Depending on what coating he used a lot of the company’s sell maintenance products.
Old Apr 3, 2026 | 06:06 AM
449er's Avatar
449er
CF Community Team
Check out Adams & Griots Garage, they have excellent ceramic products for your car
Old Apr 3, 2026 | 06:52 AM
Ystayhm's Avatar
Ystayhm
BeadMaker is a great product for detailing and enhancing the shine; use it all the time on my ‘20 Z51 3lt
Old Apr 3, 2026 | 07:44 AM
Have not tried one of the boost products yet but need to do so. I think I have some Adam’s product on the shelf so that would be a good start.
Old Apr 3, 2026 | 07:47 AM
Smokinlmm's Avatar
Smokinlmm
I have Ceramic Pro and PPF on mine and they told me to boost it with The Last Coat.
Old Apr 4, 2026 | 08:59 PM
Zormecteon's Avatar
Zormecteon
It may be the water in your area is leaving residue, assuming that you do your washing at home. Also feel your paint. It may benefit from claying. If you rub your microfiber towel over the dry surface and can hear it slide, it's time for a clay job.
Using a drying agent as you wipe the car with your microfiber towels will help, Ones that work particularly well for me include Adams Graphene BOOST, and Adams Graphene CERAMIC DETALER and Adams Graphene CS3. As mentioned above, the Griots 3 in 1 Ceramic Spray is also very good as a stand alone. (I've not used it as a drying agent)
Adams SLICK and SLIDE is great for showing the car, but it's not a long lasting solution. I also like The Last Coat AMP, but it's getting very hard to find.
I've also used (stand alone) Adams Graphene LIQUID WAX. It's easy on easy off.
Old Apr 4, 2026 | 09:08 PM
ZORANGE's Avatar
ZORANGE
I applied Adams Spray Graphene Ceramic a month after I got my car in 2022 (it's a 2023). Finally got around to re-applying it today because it's only supposed to last 12-24 months depending on how much you drive and your local conditions. I'd been noticing the water not beading up as well as it did about 6 months ago. But it's the same bottle that's over 3 years old so it'slikely past it's shelf life.
My home is about 5 miles from IAD (Dulles International), and I swear sometimes some jet fuel gets on the car--maybe from excess fuel when they refill? The cruise-in I go to regularly is even closer to IAD--only a mile away.
Old Apr 7, 2026 | 08:27 PM
Smokinlmm's Avatar
Smokinlmm
I try not to touch my car, I was instructed to use a blower to blow dry the car. I use a small plug in electric blower that does it quite quickly. Otherwise, you will get micro scratches from the cloth you dry it with and rub off your ceramic coating faster.
To Ceramic coaring
