Odd door lock behavior
Is there a way to manually set a door lock to engage after exiting the car through that door? I was going in and out earlier today but did not intentionally lock it and would use the fob if I wanted it locked. I can't tell if this is an odd feature or a bug. Thanks for sharing the knowledge.
GM engineers have said it was due to an aftermarket piece of carbon fiber that I've applied over the chrome pieces in the interior somehow interfering with the door lock on the passenger side. I am doubtful of that diagnosis but have removed the accused accessory. Autonomous locking of one door while the car is unoccupied is a new but perhaps related(?) problem. I was unaware of how to make only one door lock and that was the genesis of this thread. If there is a way to do that, I'd like to know as maybe I did it while in the car earlier that day.
Thanks for asking the question, it made me do the above experiment and I learned something, but didn't solve the problem yet. One step at a time!
There is no info as to why the Alternator only charges to 13.3 volts or the GM sold Li-Ion/Lead Acid battery charger does as well. That is about 85% capacity for a Li-Ion battery. Could be for energy savings. My E-Ray has done fine for 18 months and I have only used the GM Charger to test what it does. I typically drive several times a week a 60 mile round trip to town. Within 5 to 10 miles after the car is started the dash (alternator says battery voltage) reduces to 13.3 volts. When parked I measure battery voltage with quality Fluke VOM. Can also see the battery voltage (and not the Alternator voltage which is what the Dash displays) when using Stop/Start. The engine shuts off so the Dash display changes from Alternator voltage to Battery voltage in about 5 to 10 seconds.
I believe the Keyless door opening can be set to ONLY open the Driver's Door. That is a safety issue so if someone is watching you open the driver's car door they can't quickly open the passenger door and get in the car! I have my wife's BMW set that way.
I have my car lock , fold the mirrors and beep when I leave. Like whatever lot I I park in for anyone looking knowing the car is locked! In the garage it does the same.
