Sponsored by: CARiD
C8 Stingray Rough Idle and Acceleration after Headers
Old Apr 4, 2026 | 11:23 PM
BigChay's Avatar
BigChay
Cruising
Default C8 Stingray Rough Idle and Acceleration after Headers
I installed Race Engineering long tube headers on my C8. Noticed when header is off it does have the possibility to hit the sparks. After installing it, test drive showed a pretty severe idle and acceleration had a lot of backfire in full throttle. P0300 code popped up and flashing engine light.
checked the spark plugs since I knew they could touch the header during install and cylinder 7 had a cracked plug. Changed it. Car ran a lot better after, no codes. Slightly rough idle and acceleration was perfect until the next day when it started backfiring again full throttle around 4,500RPMs. Idle is still loads better than when the plug was cracked and all other plugs seemed.. ok, car has 20,000 miles.
should I replace all plugs? Coil wires too? Everything else seemed fine, just not sure.
vacuum lines are good, header gaskets were put on straight.
Old Apr 5, 2026 | 10:04 PM
zmpm01's Avatar
zmpm01
I would change all the plugs and the wires and install hi temp plug wire sleeve's, You might have cooked the plug wires. How do the headers route? Are the headers at all by the plug wires being they go up?
Old Apr 5, 2026 | 10:33 PM
BigChay's Avatar
BigChay
Cruising
in between the headers, about 2 inches away is the spark boots. Wires go down as the coils are underneath. Maybe 10 inches away. Coil wires have heat sleeves on them.
Old Apr 6, 2026 | 12:27 AM
zmpm01's Avatar
zmpm01
Start with the easy stuff first and take your time inspecting everything, You already found 1 cracked plug, I would change the rest of them, set the plug gap to spec. and inspect the one's removed real good for cracks and make sure you double check the plug wires and any other electrical connection and vacuum line you removed for the installation, you probably just have something simple wrong that's easy to miss, been there done that.
Old Apr 6, 2026 | 10:42 AM
BigChay's Avatar
BigChay
Cruising
Changing out all sparks on Wednesday. Never disconnected any vacuum lines besides O2 Sensors for the headers of course. Will update then, thanks
Old May 14, 2026 | 08:52 PM
BigChay's Avatar
BigChay
Cruising
Default Update
It was the spark plugs. There was a hidden crack in one of them.
Old May 14, 2026 | 09:19 PM
patton's Avatar
patton
St. Jude Donor '09
strange there was no CEL for a misfire
Old May 15, 2026 | 05:00 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Great addition for headers. Put on a set of these spark wire protectors. 1800 degree rated. GL
https://www.summitracing.com/parts/dei-010542
Old May 15, 2026 | 07:00 PM
BigChay's Avatar
BigChay
Cruising
yep! I put them on!
Old May 15, 2026 | 07:02 PM
BigChay's Avatar
BigChay
Cruising
There was, but it was a generalized misfire. Cylinders 2 and 7 had the cracked plugs. It never specified what cylinders or anything else.
Old May 15, 2026 | 09:28 PM
ArizonaZ06's Avatar
ArizonaZ06
yep! I put them on!
Great move. Had mine on for 5 years with my headers, haven't had an issue especially living in a warm environment like Arizona.
To C8 Stingray Rough Idle and Acceleration after Headers
