engine light
Noticed the car, last three months not running right, not revving quick, real slow and actually would stop and then go?
Figured bad gas, maybe, ran the tank almost dry and filled up with 93 octane, as always, did the same, would not rev quick, slow.
The engine light finally came on, after three months of this. Car has 7,500 miles.
Dealer programmer read out:
PO300 Engine misfire detected
PO301 Cylinder 1 Misfire Detected
PO307 Cylinder 7 Misfire Detected
At least I know the problem now.
It's been at the dealership two weeks, the GM team they talk to say they have not experienced this before!
After two weeks the only thing they told my dealership is, maybe bad gas! I already eliminated this, I think?
The engine light is now "Flashing" instead of just on.
Well, anyone had this problem?
If GM cannot tell tell what steps to take, what now? The dealership already said the gas is fine.
Maybe start with new plugs? Sensors? LOL
Kinda worried.
Kinda worried.
Another option is to escalate to GM to get more eyes on it.
good luck.
Only misfired the first 15 seconds or so in open loop on the initial cold start - Z06 double fires the injectors for the first 60 seconds to warm up the cats .
Flashed the MIL but didn't permanently command the light but stored the codes.
GM has a generic TSB out there too.
Put fresh plugs in and it cleared up
Don't start them up and shut them off right away (and use quality/top tier fuel). And drive them hard
- Alec
Pretty slow! I should know if it is the plugs today. I'll give them your input, sounds like this is what it is!
I'll let ya know if this was the fix.
Also, "Misty", your chips might play out! LOl
Thanks!
I knew I had a problem, for almost three months, but no engine light. After the engine light finally came on, took it to the dealer, two and a half weeks later, they finally changed out the plugs.
Needless to say I'll be finding another chevy dealer to take care of me.
Thanks to all, for telling me about the plugs, after telling the dealership they finally ordered them and put them in.
Never had a vehicle stay at a Dealership this long.
My fault for not actually "screaming" at them sooner, to get it out! A Bad Scene! LOl
The fouling of your plugs is linked to the problem that these engines tend to dilute the oil with fuel. Have you checked your oil level lately?
when you drive it. Once warmed up, beat on it. 8600rpm several times. Can't putt around 3 4k rpm and not blow that **** out.
That's the issue with an engine like this. It's fouling plugs out because many of you guys aren't driving it the way it was designed. These are the issues you'll run into over time.
Was warned about that when I had mine by my buddy who builds hi po engines so I followed the advice and never saw any degradation over the year and half and 3500mi i had the car. Many were short trips but you need open the thing up.
Alec @ Forza Motor Works
(267) 788.4897 Call/Text
info@forzamotorworks.com
www.forzamotorworks.com
Your trusted source for premium parts - offering competitive pricing, exceptional service, and professional installation options.
Corsa | Borla | AWE Tuning | Girodisc | Halltech | American Racing Headers | Milltek | Soler | Weld | Fabspeed | SOUL | Kooks | BC Forged & 100's more!
I'll be going to Spring Mountain in the next month or so, and will ask the instructors about this problem. Drove the Blackwing last month and they have a huge shop for both cars, mainly just changing out the tires! Lol
These cars get the hell driven out of them and they should know something about this, if its a major problem.
I hit a 4X4 block one night years back in my "99" vette, at 95 mph, it cracked the block! I didn't know it till I checked the oil, it looked like "peanut butter" all over the oil stick! Took it to the dealer and told me the block was cracked, they had to put a new engine in. I didn't have my night vision goggles on that night!
So, I'm going out to check the oil level, I hope I don't find peanut butter on the stick!! LOl I'm serious!
Hope it doesn't show low either, thanks for the tip Mitchell.
