Canadian Events Canada, eh?
Headers and e-test
Old 08-14-2016, 02:57 PM
Frank4202
Frank4202's Avatar
Default Headers and e-test
Been thinking about getting a set of headers and x-pipe for my 97 c5. The thing holding me back is Southern Ontarios emissions standards. With the recent changes to the program, my 97 is the last year they actually do the dyno test. Has anyone had any issues with etest after installing headers? Not sure how well it would do with different cats aside from OEM.
Old 08-14-2016, 03:41 PM
VETFEVER
Support Corvetteforum!
VETFEVER's Avatar
As long as you install cat's you'll be good to go.
Old 08-14-2016, 03:45 PM
Frank4202
Frank4202's Avatar
My last toy, after changing the cats it kept throwing p0420 codes for low catalyst efficiency. Should I expect a check engine light with the Vette too?
Old 08-14-2016, 04:21 PM
VETFEVER
VETFEVER's Avatar
Not an expert, but if the cat's are good and hot when you take it in, the efficiency should be better.
Old 08-16-2016, 12:08 AM
lionelhutz
lionelhutz's Avatar
My 98 easily passed the tailpipe test with headers before they changed to an OBDII port test.
You can get codes like that, but if tuned right those codes will be turned off as well.
Old 08-16-2016, 09:44 AM
Frank4202
Frank4202's Avatar
Is your car tuned? If so, where was it done?
Old 08-16-2016, 12:51 PM
lionelhutz
lionelhutz's Avatar
Yes, by me.
Old 10-15-2017, 02:45 PM
Frank4202
Frank4202's Avatar
Yes, by me.
Still looking into this. Might go with shorties and keep the OEM cats.
Old 10-15-2017, 06:54 PM
SladeX
SladeX's Avatar
Before the change over to ODB2 only for 98 up, I was passing the dyno test with my cammed, headers, 98 camaro.
The key is to have cats installed AND a good tune. Without the tune, it will be hard to pass. The tune required should be done on the street to better dial it in, the dyno tune doesn't do much for street conditions.
Old 10-17-2017, 12:33 AM
lionelhutz
lionelhutz's Avatar
You'll gain so little power that shorties are hardly worth the time and money.
Long tube and decent quality high flow cats will pass if tuned right.
Old 10-21-2017, 03:46 PM
Roadking103
Roadking103's Avatar
I had ARH x pipe and high flow cats on my supercharged 03z06. Paased Ontario e-test no problem. Tuned by Kevin at Champion motors
Old 10-24-2017, 09:36 AM
Frank4202
Frank4202's Avatar
Too expensive. Not sure I wanna make the 4hr drive to Champion either.
Old 10-26-2017, 02:49 PM
Pompitup
Pompitup's Avatar
Check out performance shops in Michigan seeing as your close. Lots of great shops there like Katech and Lingenfelter.
Old 11-01-2017, 03:10 PM
Cap'n Pete
Cap'n Pete's Avatar
When I had headers installed on my '02 Camaro years back, I didn't run the rear set of O2 sensors, which would have thrown a code, so I had a shop program out the rear sensors altogether. The front set of O2 sensors are what control your air/fuel. The rear set provide the data for "catalytic efficiency". By deleting the rear set, that's no longer an issue.
To Headers and e-test
Quick Reply: Headers and e-test
