Warbling sound
Warbling sound
just wondering if anyone here has experienced the warble from the diff. in the 2016 / 2017
i have been following this thread, too long to read them all, over 1000 posts, but you get the drift. and what has is your experience at getting it resolved ?
https://www.corvetteforum.com/forums...asionally.html
Warbling sound
[QUOTE=walleyejack;1594027217]just wondering if anyone here has experienced the warble from the diff. in the 2016 / 2017
I experienced the same "warble" sound depicted in the main thread. ( 2016 Z51 A8 )
To my ear, though, it sounded like it is coming from underhood. I only noticed it after installing the AFE-Momentum air intake.
As the car is currently away for the winter I'm waiting till spring and returning the intake back to stock to see if the "warble" is still present.
I'm not sure if this helps - but since the drive shaft spins a lot faster - might any warble sound be more likely to come from a rear universal - if there is still such a thing?
no sir.. gm definately knows about the issue, and trying to bury it. some have had ring and pinion replaced, same issue, some have had newer version of diffs installed and that resolved the issue, but GM has not resolved the problem yet.
Al, has this been an issue for you since you got the car?
Frustrating I am sure. Good luck getting it fixed.
Al
I hope you don't have it blow up on you - cause I've been there & it's not a fun ride when that happens - hahaha.
This also reminds me of back when I had what was then a common problem - of chattering sound in the posi-traction in my TransAm... all GM did was suggest an additive to the diff fluid.
If things were only that simple for you in this case.
hey Murray, started probably a month later, mostly when is cold in the am, but have been noticed it more and more anytime, is a real problem with guys in the US. i have been following the thread. will see how it plays out. for me, not a big deal, just aggravating noise that should not be there and should be resolved, i have not pursed the issue as waiting to see how it plays out down below and can t get the car out anyways. that is why we have warranty, if it blows up it blows up.
Al
Al
walleyejack (02-08-2017)
Totally a warranty issue when the car makes sounds it should not make. Take it to the dealer and make hem fix it. Don't accept "it should sound like that - this is normal". As a minimum, it gets the issue recorded in the system for your car so you have proof it happened early in your ownership. The longer you sit and tolerate it, the more excuses they will have about wear and tear and that it was something you did...
i am assuming, no one in Canada has the warbling issue, lots of US guys using the lemon law and sending them back, and getting screwed on the price. and gm say, too bad, that s the way it is. they are still denying any issues. "just normal" is what they are telling everyone. BS.
As soon cars come out of storage - people should start listening closer.
I haven't read all the posts - so can you tell me if this has been reported in all year C7 up to 2017 - cause the lack of others noticing this sound does seem strange...?
Stickshiftsteve (02-13-2017)
[QUOTE=8SPD Z51;1594034339]
I have the warble sound in my 2016 z 51 7 speed. It comes from the rear and just started at 9,000 miles.
Just turn the radio up louder Al!
i don t have the issue like the A8 s do, mine is only a nano second from a stop, so it doesn t last long, i m not worried about, blow up, who cares, warranty. i changed the diff fluid made a bit of difference, i suppose if the dealer had filled it up to begin with i would have the noise even, was down a thimble full short of a litre.
