Where in the GTA to buy Z51 Replica wheels
Hi everyone.
New to the forum as I am picking up my C7 in two days. This is going to be my daily driver and I intend to drive it over the winter. As such, I am looking to get a set of Z51 Replica rims in the 18/19 sizing to put winter's on them.
Looking for recommendations on where I can find these in the GTA. Other thoughts about winter wheel / tire set up would be welcomed.
Thanks.
Thanks.
I know a few from our HDR's and cruises that have gone to http://www.bramptontirewarehouse.ca/ in Brampton and have no issues. Been meaning to out there myself, just finding the time.
Inexpensive repro's.
i3kc (06-13-2017)
Yeah, on the C7, the Z51 wheels are actually 19/20 combination due to the larger Brembo rotors and calipers. The base C7 had the 18/19 combo.
I'm not sure you'll find a 18/19 combo to fit the larger rotors.
When I talked to the supplier, they advised me that they are close to getting something for the C7, but it would only come in the 19/20 combination. Looks like there are very little options (appears take offs are the only economical option) for a base Stingray (To mount Winters).
I'm starting to lean towards using the OEM 18/19 for my Winters and buying OEM Z51 take offs or something in the 19/20 combo for summers. Probably just swap Summer/Winter tires each season change over until the summer's are worn, then look for something then.
If you want a set of nice wheels that have the proper offsets check out these. I have Cray Spiders as my winter set.
The first set of wheels that I ordered (that were stated as a guaranteed fit) had terrible offsets and they hung outside the fender.
https://www.corvetteforum.com/forums...post1594355955
There's a vendor on this forum called House of Wheels. He has all sorts of tire/wheel combos.
You can try the classifieds. There are some deals to be had. I got a set of speedline wheels, tires, and sensors last summer for $1700 USD. Even with the poor exchange I got a good deal.
Can a C7 handle snowstorms and unplowed streets even with snow tires considering the Z51 rear tires are quite wide (285/30/20)?
Side note: During the winter time, I started to miss it and brought it out a few times when the temps > 0 and roads were clear, aside from the strange looks I was getting (and someone actually questioned why I had it out in the winter), it wasn't very comfortable getting in and out with a bulky jacket etc.
Also, I have never tried, but can it go through a regular car wash where the tires go through a rail, without damage to the rims? I usually either hand wash it or take it to a touchless wash (without the rails), but always wondered whether the Z51 rears cleared those car wash rails.
The problem with Corvettes in the winter is the ground clearance. Even with the right tires, you can't get over the problem that even at stock ride height you're going to have snow hitting the bottom of the car A LOT. And if you have to drive on a street where they leave you one of those "snow barriers" from plowing, forget about it, you'll destroy your front end trying to drive through it. Best to just take it out when the snow is very light or non existent, and take another method to get around during and immediately following any major snowfalls. I drove my old C5 through 7 Toronto winters but whenever we got a major storm I borrowed a car or stayed home from work, it wasn't worth the hassle.
As far as car washes go, with the C5 I had a weekly appointment at a local detail shop to get it handwashed. Back then they only charged $10, so that was a no brainer. Now I think the price is closer to $20 so it's not quite the bargain. But you can always go to one of the many available car washes at Canadian Tires and Essos where there are no rails that pull you along but instead you drive up to the center of the wash and the car gets sprayed over by a completely touchless system.
Lucky for me, I have a touch-less car wash without rails right by my house. It's the one where the car parks inside the unit and they apparatus rotates around the vehicles and washes. When I'm done, I just drive out.
I know the practical solution is to get a winter beater, but what fun would that be?
Patman hit the nail on the head. Ground clearance is the only restriction of driving in the winter.
A good set of winter tires give you very good grip and the traction / stability control on the C7 is very good.
I'm not sure if you guys in Toronto remember that first major snowstorm last winter on December 15th. I drove in heavy deep snow down the Gardener and QEW just fine. Cars with all season tires were getting stuck.
Hi everyone.
Just took delivery yesterday and can't be more happy. After driving her around for a bit and reading everyone's thoughts on driving in winter in Canada, I am more than confident that it won't be an issue. I found the power delivery very smooth and not "torquey" and the ground clearance at stock set up not too low. I've driven imports with less ground clearance and never had and issue (with winter tires, All seasons was a different story). At this time, I'm going to put finding wheels on the back burner. I'll likely go a few seasons of swapping tires until the summers that came with the Vette need to be replaced. At that time, I'll look for a 19/20 set up for summers and use the stock 18/19 for winter. That is of course unless I come across a super deal.
Shout out to CanadianVetster for the front splitter. My first mod, hours after taking delivery.
Thanks again for everyone's input.
Congrats!!
Remember when shopping for rims, be sure to test fit them on the car first before mounting the tires. The offsets on vettes are very unique.
A lot of rim manufacturers will not take the wheel back if tires are mounted regardless of whether they fit.
Yeah, that would not be good. I was thinking about it the other day. It is an indoor ladder, maybe time to move it to the basement!
That is a great looking C7! I love the base wheels in silver, most people opt for them in black, but they look way better in silver IMO. You've got the last year those wheels are available too, for 2018 they have discontinued the 18/19" wheels and all Stingrays get the Z51 style 19/20" wheels.
Yeah, the 18/19 wheels from the base 2016/2017 have such a limited run. I'm glad that they are making a standard wheel size across all trim lines. I hated buying cars and having to upgrade the wheels because a higher trim had larger wheels (for aesthetics).
