Gas ? Winter Storage
So, just wondering what others use - do you fill up with gas with or without Ethanol when storing car for the winter??
Usually, I fill up with Petro Canada 94 with a dose of Sta-Bil.
But, what about Shell 91 without Ethanol?? Better or worse??
Any thoughts - recommendations?
TIA
TIA
Due to a series of circumstances I didn't attempt to start a car that I store (indoors) for over 5 years. When I finally went to start it the old gas was perfect. So I think wintering for a few months is no issue at all regardless of fuel.
I have always heard that it's best to store the car with ethanol free gas, so that's what I always do. I already run mostly Shell or Costco anyhow (both of which have no ethanol)
Ethanol is hygroscopic, so it attracts water to a greater degree than gasoline, which over time is bad news for your fuel tank, fuel lines, fuel pump and engine. Now, in a closed tank for a few months its very unlikely to develop into a serious issue, but my philosophy is that a little insurance goes a long way. So, a few more cents for Shell 91 and about $10 for a bottle of Stabil is a small price to pay for piece of mind and proper care of the equipment.
Actually they now recommend storing the newer Corvettes with under a 1/4 of a tank, so that the fuel level sensors don't get gummed up. This recommendation comes from one of the top Corvette mechanics in the US, the idea is that when the car is just sitting for a long time, if the sensor is submersed in fuel the sulfur can gum it up. But if stored with under a 1/4 tank this won't happen (or if you do what I do and drive it every couple of weeks whenever the roads are dry and free of excess salt)
Non-ethanol fuel, Marine (green-blue) Sta-bil and a completely topped off tank (to avoid condensation) every winter. That, and a Battery Tender charger has worked for me in 35+ years of winter storage of motorcycles and ATVs Well, I used to use Marvel Mystery Oil in ancient times before I found out about Marine Sta-bil from my boating friends.
FWIW, I recently found out that all of the major gas station's 91 octane contains no ethanol. So not only Shell and Costco, but Canadian Tire, Esso, Petro Canada and even Ultramar all have no ethanol if you choose 91 octane.
Received 1,500 Likes
I haven't checked recently except for Canadian Tire all of the pumps said that it contains up to 10%, I wonder if the labelling has changed at the pumps now?
Yes, I have read the recommendation of 1/4 tank of gas. Unfortunately that means planning my driving and fill-ups to get to the 1/4 point. I like to get in as much driving as I can right to the end (Dec. 1) if the weather permits. So the gas ends up at whatever it's at. Anyway, I store the corvette in a heated garage so I really don't worry about the level of gas for the 4-month period.
john
I don't think condensation in the tanks are as big of an issue as they used to be in the old days. When was the last time you heard of a modern Corvette having problems due to condensation in the tank? Probably never. But there are a ton of people on the C5 and C6 forums who have posted problems with the fuel level sensors getting gummed up, and the procedure to replace them is very labor intensive. I choose the option of protecting them.
I've just parked my cars when winter arrived and have never had an issue. Been doing it that way for many years now. A while back Dad decided to try a fuel stabilizer type product in his stuff and everything he put it in had issues in the spring. So, I'm not convinced it matter either way for a single year of winter storage.
All newer cars have sealed fuel systems so there is no reason to think that a bunch of moisture will get into the fuel system of a newer vehicle.
