california duster q...
Maybe a dumb question, but here goes...
I've never used a California Duster before, but my thought is this...your car is perfectly clean, washed - waxed, etc....you drive around for a bit and you get some dust/dirt on it...you pull the duster out...and after a few swipes you have a pretty much dust free car, but doesn't it scratch??? Just wonderin'...let me know what ya'll think...
JimO
Erie, PA
JimO
Erie, PA
I have a black coupe that I use it on all the time and it saves me a lot of work. Let the duster do the work and don't use pressure. Just make sure it is only light dust and never use after it has been rained on. Works great.
I agree...I got a black 02...use it all the time
Location: Ponte Vedra Beach / London State: Dazed and confused
Car Duster:
The best known brand (California Car Duster) it can be used to remove pollen or light dust without causing scratches by applying very little surface pressure with the duster, dusting with long strokes in one direction only. Shake the duster occasionally to ensure any particles picked up will drop out rather than come to the surface while you’re using it. It important to use the duster only for the removal of dry surface dust, if the vehicle has oily road film, road tar, damp pollen or dust, etc the vehicle surface should be washed
Dust build-up-with low humidity conditions friction on the paint surface will cause static electricity (this is exacerbated by the use of polyester (nylon) Microfiber) resulting in dust attraction to the paint surface. Rinsing the surface with water or applying a quick detailer (QD) or use the CCD as stated above to remove dust
When the duster is first purchased it should be wrapped in newspaper (48 hours) to remove any excess paraffin wax, the duster should not be washed, the dirtier it gets the better it works (I've been using mine now for almost five years without it being washed) http://www.calcarduster.com/faq.asp
JonM
JonM
Make sure you do not rub hard, especially on black. I use mine all the time but I drag it over the surface so that the ends of the strands just barely touch picking up the dust. I see people all the time with the whole duster laying on the car, some even applying pressure and cringe.
Used properly, a California Duster is an excellent detailing tool. One point I'd like to make in it's use though, is that it is best for use from the beltline of the car and up. Beneath the beltline you tend to pick up road oils/grime and you really don't want that stuff on your duster. Use quality microfiber towels and a good Quick Detail Spray for the lower part of the body.
Wow...thanks EVERYBODY!!!!
Sometimes I'm amazed at the info available through this forum!
JimO
11 more student loan payments until I own a Vette!!!!!
Erie, PA
JimO
Erie, PA
Former Vendor
One of the single greatest hints, otherwise streaking will be noticed and product will be returned. Oxo makes an awesome one also ... and I like it JUST cause its blue !
http://www.autogeek.net/oxo580.html
I have been using the same California Duster for over 2 years. Remember the dirtier it gets, the better it is. I "dust" my Vette at least 4 times a week. Amazing how much dust it picks up parked in the garage!
yep -- count me in, agree with all the above.
hard to remember how old my duster is -- there's a good chance it's 9 yrs old. The only one i've ever had. have never washed it. never a scratch.
only use it on dry dust and pollen on the hood and trunk, and highest parts of the sides. Never on the cloth roof (convertible) -- will make a mess there.
California
JimO
Erie, PA
JimO
Erie, PA
CI 6-7 & 9 Veteran
Originally Posted by C5-BRUCE
By now you've read all the pluses about the California Duster, and I concur! But there is another product from this company called the California Water Blade. It's a silicon squeege that wipes off the water after washing. Really saves time in drying your car, but there is one caution. Be sure your clean it before using it!
Originally Posted by crawfish333
I have been considering getting a California Water Blade to aid in my battle against hard water spots. (already using Mr. Clean kit) I have also used a leaf blower and it helps, but it is so hot in Louisiana this time of year that it is hard to get the water off of the car before it spots. The only concern I have about the blade is the possibility of scratching the clear coat. Problem? Any other advice before trying this thing on my blac C5 coupe?
I would stear clear of the water blade, one little piece of grit on the surface and you have a nice scratch. I would use it on the windows but that is it.
CI 6-7 & 9 Veteran
I tried the water blade yesterday in 100 degree weather washing the car on section at a time. I also used the Mr. Clean soap and filter. I got pretty fair results, only a few spots. If I could keep the overspray off the parts I have already washed and dried, it would probably be perfect. But alas, I guess I'll just do the best I can to prevent spotting, then claybar and reapply Zainos in September - October, when temperatures begin to moderate. (I hate summer)
100 degree weather?
I tried the water blade yesterday in 100 degree weather washing the car on section at a time. I also used the Mr. Clean soap and filter. I got pretty fair results, only a few spots. - October, when temperatures begin to moderate. (I hate summer)
