Water Spot Removal???
Any ideas??? Did the wash / wax thing x2 and no luck on the water spots being removed. Using Maguire's products exclusively.
Took the Vette (Dark Metallic Green) to a shop (no indoor storage)-rained, then left in the sun...now I have funky spots all over her that I can't get rid of.
Any help would be appreciated.
THX
JTK
THX
JTK
There is a chance that the spots are etched into the paint.
Start out by trying some distilled white vinegar. Then try a claybar if it's still needed. If those things don't take care of the problem, you'll need a paint polish to remove them from the paint.
This car is a recent purchase...the previous owner was a regular car wash user and there were significant scratches in the finish...two weeks ago I went through the Maguires polish series with a heavy (8), then light (2) then the swirl remover. The results were amazing-new car like finish once all said and done.
I'll try the vinegar bit...sounds like a great plan.
Many thanks!
JTK
Many thanks!
JTK
Before attempting to abrade away the spots what you want to do is "dissolve" the spots.
This can be tried with vinegar or the brave soul may try some wheel acid. I have never done the wheel acid but other pros have told me it works great. They wet the car down then dip a towel in the wheel acid and pretty much apply it as if they are washing the car. Rinse well then re-wash. Be very cautious if using hydroflouric wheel acids as these can be harmful healthwise.
Anthony
Anthony
A wax with some good cleaners in it like Mothers Reflections should do the trick. If that doesn't work, try Goo Gone or turpentine. You would be surprised at Goo Gone's ability to dissolve just about everything. That stuff is amazing!
VETFVER
VETFVER
VETFVER
VETFVER
First a cleaner/wax does not have enough umph to remove hard water spots (if this is what they are). If these are water spots then they are most likely mineral deposits and Goo Gone won't touch them.
Lastly, turpentine works for tree sap but I don't believe it will do anything for mineral deposits
If they are REALLY set in, you might try what I did.
sure, try vinegar first - it won't work.
no amount of waxing with mothers or Meguiar's cleaner wax will work (tried it).
When your serious - do this
See my post here for the details .
here are the pics before:
after:
don't need an electric buffer -- just use a terry cloth towel. A little bit of work, but excellent results.
- wash with dawn dishwashing liquid
- Use 3M fine cut rubbing compound
- you may or may not want to follow with 3M swirlmark remover. It's supposed to get rid of any scratches left by the previous step, but in my experience it is not necessary and does nothing. the rubbing compound is fantastic alone.
- then apply your favorite sealant or wax
after:
I have been defeated by the spots
Well folks...I have been defeated thus far by these retched spots. My Polo green coupe looks like the back of a green bullfrog with the pale spots all over it.
We did the wash thing, then washed with a 50/50 distilled white vinegar and water-results were exactly zero.
Then went full strength with the vinegar on the hood...
results still zero
Then we went for the big guns...maguires moderate cutting polish (#8) on a random orbital buffer
THEY WERE STILL THERE-laughing at me with a sinister grin
Claybar the next step or is there a commercial product I should try? These spots are horrible.
JTK
results still zero
JTK
Location: Ponte Vedra Beach / London State: Dazed and confused
For stubborn water spots use Auto International's A, B, C System, a safe alkaline wash and neutralizer system (http://www.autoint.com/)
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
If that doesn't work, try Goo Gone or turpentine. You would be surprised at Goo Gone's ability to dissolve just about everything. That stuff is amazing!VETFVER
Update - just had some rain, and some FRESH water spots on a different vehicle. For these spots, on a car with NXT already on it, and where the spots had not been baked in for years, but just a few days, Meguiars Scratch-X worked great -- all gone.
Had this tube of scratch X for about 4 years, never found it useful in the LEAST to remove scratches. Now I've finally found it's use. -- great for FRESH water spots.
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Originally Posted by Crusher
You got to be joking!
THX
JTK
THX
JTK
Try this..I have a black car and had the sprinkler system hit it and bake on the next day..
Problem with Abrasive cleaners is that it hits the surrounding Clear Coat too..
I wanted to attack the calcium directly..
I tried C.L.R., Vinegar, Claybar.. Nothing got it COMPLETEY off.. They all left a calcium ring.
Then for the hell of it.. I tried using some Zaino Z1
The Z1 Dissolved it completely.. I spoke to Sal about the chemical makeup of Z1 and why it worked so well and he really had no idea...
It did work and made the paint baby smooth..
One tip first is to remove the crusty part 1st using some CLR or vinegar... then follow up with the Z1...
