Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Silly Zaino Question
Old 08-03-2001, 04:10 PM
4THTOY
4THTOY's Avatar
Default Silly Zaino Question
Is it possible to have to many coats? I enjoy the look of a fresh coat I end up putting a fresh thin coat of Z5 on the car every 3-5 days, (I use Z1 after every 10 coats) I must have 50+ coats on it now.
Ira
Old 08-03-2001, 05:23 PM
KLO
KLO's Avatar
Default Re: Silly Zaino Question (3rdtoy)
Nope, can not have too many coats.
Old 08-03-2001, 06:07 PM
96LT4
96LT4's Avatar
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Default Re: Silly Zaino Question (KLO)
Sal loves to hear of people putting on tons of coats. Keeps his products moving!!
Old 08-03-2001, 08:11 PM
edz
edz's Avatar
Default Re: Silly Zaino Question (96LT4)
3rdtoy
you probably got enough Z5 on it. Now switch to Z2 to get the best shine.
Old 08-03-2001, 09:19 PM
hcvone
Support Corvetteforum!
hcvone's Avatar
Received 1,767 Likes on 969 Posts
Default Re: Silly Zaino Question (edz)
In this shot the car probably had 30 coats, now over 50 :eek:
Old 08-04-2001, 03:42 PM
JDC5
Cruising
JDC5's Avatar
Default Re: Silly Zaino Question (hcvone)
Other that once or twice a year, is it necessary to use Z-1? (I.E. - After a certain number of coats of Z-5 or Z-2) After using Z-5 and Z-2 and it's time to use Z-1, then what is the preparation process? Is it the same as when you start the Zaino process? (I.E. - Clay, Z-1, Z-5, etc....? Thanks for your help.
Old 08-04-2001, 03:48 PM
KLO
KLO's Avatar
Default Re: Silly Zaino Question (JDC5)
You use Z-1 once a year for a show car or garage queen, twice a year for a daily driver, and Sal has said if you like to apply Z-2 or Z-5 often to use Z-1 after 10 coats of either, no special prep is involved for the Z-1, you can put the Z-1 on top of however many coats of 2 or 5 you have.
Old 08-04-2001, 05:22 PM
JDC5
Cruising
JDC5's Avatar
After using ten coats or so of Z-5 and Z-2 and it's time to apply another coat of Z-1, do you apply either Z-5 or Z-2 before removing Z-1 as in done in the start up process? Thanks for your help.
Old 08-04-2001, 06:25 PM
KLO
KLO's Avatar
Z-1 can not be used by itself, you must put Z-2 or 5 on top of it everytime the Z-1 is applied.
Old 08-05-2001, 12:01 AM
ASTROS
ASTROS's Avatar
hcvone......
do you have seat covers on
[Modified by ASTROS, 1:02 AM 8/5/2001]
Old 08-05-2001, 12:12 AM
georgehafe
georgehafe's Avatar
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
JDC5, You should not have removed Z-1 at all. You put it on and leave it on, go over with Z-2 or Z-5.
Old 08-05-2001, 09:01 AM
hcvone
hcvone's Avatar
Default Re: Silly Zaino Question (ASTROS)
No seat covers just a wierd looking head rest image, light oak top and interior.
[Modified by hcvone, 8:03 AM 8/5/2001]
Old 08-06-2001, 03:02 AM
JDC5
Cruising
JDC5's Avatar
What is the best technique for applying Z6. I've been misting about a one square foot section then rubbing it in with a 100% white cotton bathcloth then finishing the section off immediately with a dry 100% white cotton bath towel. As I continue, the bath cloth used to rub in the Z6 gets damp. Am I wasting Z6 with this application technique? Any input will be appreciated.
Old 08-06-2001, 03:09 AM
JDC5
Cruising
JDC5's Avatar
Carl,
Is it best to apply Z6 immediately after removing Z5 or Z2 and also before applying the next coat of Z5 or Z2 if there is about a week between coats? Thanks for your help.
Old 08-06-2001, 03:17 AM
KLO
KLO's Avatar
I think you are using too much Z-6, just dribble it on the finish and spread around, no need to entirely cover that one foot section you are using with Z-6, I use 1/4 of one bath size towel and it does not get that damp. You can also mist the towel FIRST and not the paint.
Old 08-06-2001, 03:18 AM
KLO
KLO's Avatar
Carl,
You can use Z-6 any and all times, before, after, any hour, second, day of the week.
Old 08-06-2001, 03:46 AM
JDC5
Cruising
JDC5's Avatar
I realize that Z6 can be used at anytime between coats of Z-5 or 2, but what I want know is applying Z6 immediately after removing a coat of Z-5 or 2 and again applying Z6 before the application of another coat of Z-5 or 2 (a week or so after the first coat was removed) the generally accepted way to approach to the Zaino system. The reason I ask this is I recall Sal mentioning in this application instructions that most of his customers after removing a coat of Z-5 or 2 and before another coat of Z-5 or 2. Are these two specific times that Z6 should be used or is it necessary to apply Z6 at all between coats of Z-5 or 2? I do want to get the best results possible and plan on a coat of Z-5 or 2 each week. Sorry if I seem persistant, but I want to learn the best of the best tips. Thanks for all input. :bigears
Old 08-06-2001, 10:49 AM
KLO
KLO's Avatar
Absolutely
It is not TOTALLY necessary, but the Z-6 brings up the gloss and adds an anti static charge.
Old 08-06-2001, 05:30 PM
4THTOY
4THTOY's Avatar
edz
I tried Z2, but thought the car had a better shine with Z5. Z2 seemed to dull the shine that was there, (yes, I let it dry) so now I only use Z1/Z5/Z6.
Ira
To Silly Zaino Question
Quick Reply: Silly Zaino Question
