Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Water Spots
Old 04-23-2007, 04:13 PM
Sunset
Sunset's Avatar
Default Water Spots
My son did me a nice favor and washed my car. He did not get all the water off and now I have hard water spots. I washed and waxed it this week-end , but I can still see there are spot. Anyone have a good way to remove the water spots.
Old 04-23-2007, 04:14 PM
Low12s
Low12s's Avatar
Location: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Use Soft Water
Old 04-23-2007, 04:17 PM
atomic orange vert
atomic orange vert's Avatar
If it just happened this weekend, a good quality polish should be all you need.
Old 04-23-2007, 04:47 PM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
Default Vinegar
For serious hard water spots on my C6, I have used distilled white vinegar (full strength). Used a clean cotton rag to wet area with vinegar and then rubbed hard with same rag. It removed all my spots with no damage. Take vinegar off with soft water and dry. For less serious spots you can dilute the vinegar or not rub.
Old 04-23-2007, 04:54 PM
Arizona Z
Arizona Z's Avatar
Clay bar will remove water spots....I have also had luck using your favorite road tar remover but only if you have just a few spots.
Old 04-23-2007, 04:55 PM
4thC4at60
4thC4at60's Avatar
Received 2,888 Likes on 1,296 Posts
Vinegar is also very hard to beat on cleaning windows and mirrors.
Old 04-23-2007, 05:46 PM
Sunset
Sunset's Avatar
Thanks for the vinger advice. I will try the 50:50 mixture first. I am assuming you do not have to rub very hard.
Old 04-23-2007, 05:55 PM
rjr2007
rjr2007's Avatar
This will work, I do this on my boat to get the spots off.
Old 04-23-2007, 08:01 PM
06C6Z
06C6Z's Avatar
Originally Posted by Low12s
Use Soft Water
Good waxing.
Old 04-23-2007, 09:38 PM
Sunset
Sunset's Avatar
I used the 50:50 mixture and it worked great. Thanks
Old 04-23-2007, 09:44 PM
Dave1
Dave1's Avatar
St. Jude Donor '09
A mild polish with a PC will probably remove your water spots. After that process, re-wax or use a paint sealant to keep your finish protected......
To Water Spots
Quick Reply: Water Spots
