Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
tree sap
Old Jan 1, 2008 | 04:21 PM
Lancer033's Avatar
Lancer033
Default tree sap
any good tips on how to get tree sap off a car short sandpaper? looks like it's been there for a while and normal wash/clay bar didn't even put a dent in it.
Old Jan 1, 2008 | 04:50 PM
GS4-LT1's Avatar
GS4-LT1
I have used a hair dryer to soften it up and then work it out with Bug&Tar remover. Follow that up with a good paint sealant or wax or your choice.
Old Jan 1, 2008 | 06:30 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
To remove the tree sap from your vehicle's surface, you can use finger nail polish remover on a cotton ball. After the sap is removed, make a paste of water and baking soda to wash the affected area, then apply wax.
Another method to remove the sap is to use mineral sprits (it will also remove tar). Use a soft, terry towel, or wash cloth dampened with mineral sprits. After removal, wash the car and apply wax to the affected area.
Tree sap can also be removed by using a water-soluble paint brush cleaner. A common household solution is bacon grease or lard. Just rub it on, and off comes the sap. To get tree sap off of your hands, simply rub mayonnaise on them and wash it off. To remove tree sap and other substances, you can use common solvents like lighter fluid, rubbing alcohol, WD-40 or even Skin-So-Soft bath oil.
Best Regards
John
Old Jan 1, 2008 | 07:09 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
Remove bulk of Sap with a plastic razor blade and the soak with GooBGone to remove the remaining film of sap. If left on the surface for any length of time it will eat through your clear coat.
Old Jan 1, 2008 | 08:53 PM
steve8's Avatar
steve8
Put a small rag with plenty of wd-40 on it. Let it sit there for as long as overnight if necessary.
Old Jan 1, 2008 | 08:56 PM
maxp's Avatar
maxp
hair dryer + goo gone. I would not use acetone (fingernail polish remover)
Old Jan 2, 2008 | 05:57 PM
nmerhaut's Avatar
nmerhaut
Fingernail polish remover is acetone. Read the lable for that. Try a little kerosene.
Old Jan 2, 2008 | 06:14 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
soak it with a little poorboys bug squash and usually comes off in the wash.
Old Jan 2, 2008 | 06:36 PM
0JPM@AutoBuffs
Former Vendor
Mix 50/50 with water and you will be fine!
Old Jan 3, 2008 | 05:34 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Use caution with Acetone. as well a being fingernail polish remover its also a heavy-duty degreaser; it thins polyester resins, vinyl and adhesives. Acetone can also thin out or dissolve fibreglass, and many plastics, including polyurethanes (clear coat)
To tree sap
