Ask the Autogeek! Question & Answer Thread
#81
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
I am interest in correcting my paint on my Vette...It is Dark Green...
I need more info on what Menzerna Polishing Compounds and pads will be needed.
The paint is swirled with some deeper scratches and scuff marks. I will clay first and then use Menzerna, wash with dawn and then ole trusty Zaino. What would you suggest I use to correct my scratches/swirls/scuff marks..
Thanks!
Adam
Thanks!
Adam
#82
Former Vendor
Thanks!
Adam
Thanks!
Adam
Adam,
Do you own a buffer ?? If so what type ??
Most suggest a combo of Menzerna SIP with orange pad and then Menzerna Nano polish with a white pad on buffer. You however suggest that the scratches are deeper, so you may need a rotary buffer and a wool pad or two. Id suggest calling us, its toll free and speaking with Dwayne, Meghan, or Jason. Tell them your from the forum and they will help once they can find out the items you have and then provide a list of whats needed.
By the way ... no real need for Dawn in car care. Even if using Zaino as your protection, abrading the surface with a polish like Menzerna removes all the old wax and contaminents anyways. It can dry out your weatherstripping over time, so just a suggestion. And If using Zaino Id suggest Z5Pro once done with Menzerna.
#83
Here i just want to share some idea about car care, car detailing. I own a blog talking about car care simple tips. May you see it. hopefully it can help you. glad to sharing.. cheers.
==HEAVENS OF CAR LOVER==
#84
Former Vendor
http://www.autogeek.net/detailingtips.html
#85
I have ordered Wolfgand total swirl remover and I like the product but I still see a few minor swirls and I'm thinking of ordering mezerno SIP.Is this product any better or should I just stay with Wolfgand.I use a PC 4230.
#87
I purchased the Menzerna Flex XC3401 Ceramic Show Car Kit in January ( Thanks) and have been looking forward to using it. I wanted to ask you what wax you recommend for the final step, but in reading this helpful thread I see that you answered my question already: Pinnacle Souveran. However, I became confused looking at the many choices, such as:
Pinnacle Souveran Carnauba Paste Wax
Pinnacle Souveran Liquid Spray Wax
Pinnacle Liquid Souveran Wax with Polycharger
Are any of these recommended, or is there another Souveran Wax I should be looking at in particular?
Also, I have leftover wax from another kit: “A---’s Buttery Wax.” It contains both carnauba and polymers. Would this be okay to use up first?
#88
Former Vendor
Souveran Paste Wax is often talked about in many posts as its a show quality wax. You could consider its little brother Pinnacles Sig Series II Paste Wax if you wanted a little longer protection is adds the polymers like that "other" (smiles brand). Dodo Waxes Hard Candy is another paste wax that would bring some rewards to such a sweet color. The Souveran Spray Wax version can be used over any wax or sealant to add that "just waxed" look.
And yes you "could" use up that other wax first as wanted, just remember when you change and try one of the three I suggested above dont blame me if you wish you did so sooner !!
#89
#91
Probably been covered before but keeping a black car swirl free is next to impossible. I've been a long time user of Zaino products and have tried their swirl remover but with unsatisfactory results. I love the durability and shine of Zaino but it doesn't really stack up on finishes that are less than perfect. I want to start over and try a new approach and am considering Turtle Wax Black Box even though as a rule their products aren't highly praised on the Forum. I have a buffer and really need a polish that can reduce the oxidation and swirls on my black car without the possibility of further damage. I'd love to have it professionally buffed and detailed but I live in a remote area where detailers are as rare as good economic news What would you recommend as a starting point? Thanks
#92
Former Vendor
http://www.autogeek.net/dual-action-ceramic-kit.html
The Menzerna polishes work much easier on the Vettes coat, and this kit has everything needed for a PC or G110. If you have a Flex, we have that kit also. You can still use the Zaino sealants (Z2, Z5) as wanted also for protection.
Try to use good washing and drying techniques which will reduce swirls too, if you need hints just ask !
#93
Just finished the car using the Menzerna Flex Ceramic Show Car Kit and I am very pleased I do have a quetion that I have seen addressed at least once or twice before but cannot locate the thread, so I hope you don't mind me asking here...
How should I store the foam pads after I've cleaned them? Should they be stored while the pads still retain a slight bit of moisture in a sealed plastic bag (Ziploc) or allowed to dry thoroughly before protective sealing? Thanks!
#94
Former Vendor
#96
Newbie Question
Hi Guy's I have a 92 that is in very good condition (Paint wise) but i do not believe that it has ever had a good cleaning. I am new to this and know almost nothing about polish, clay bar etc. can someone help me out with what i need to clean the finish and add a deep wax look, without damaging the finish?
#97
Former Vendor
Then decide on your comfort level as to each step in detailing.
Washing --- Claying --- Polishing (or paint cleansing) --- protection
Claying is much more simple and you will do well. As long as you use lubrication and cup the clay (not grind) along finish youll be amazed at what it pulls off and out.
Polishing is a necessary evil, in which a machine is needed and abrasive polish. It removes old waxes, oxidation, and swirls if done properly. Slow and patience is the key and a safe buffer (Random Orbital) is the perfect choice.
Paint Cleansing is for those that dont polish and want to at least chemically strip old waxes and oxidation. Using a lotion , its just like waxing with application and buffing off. Pinnacle and P21S make very easy to use lotions ...
Call us if you need help and to order, its toll free
#98
Foamgun Question
I just used my foammaster gun for the first time. Awesome foam! I have the bigger size container and was wondering if I can leave the unused solution in the container for next time or should I pour out into another bottle? In NC today it was about 80 and I did notice that leaving the foam on too long caused it dry and spot even though when I started washing it washed away. Should I rinse away the foam before I start washing with my two bucket system or is it OK for it to somewhat dry before I get the entire car washed?
Thanks Hank
Thanks Hank
#99
I will be receiving new wheels soon!! They are a 3 piece wheel with carbon fiber and black chrome lip all clearcoated. What is the best cleaner and wax for this material. I have been using P21s wheel cleaner and Poor Boys wheel sealant on my chrome Z06 wheels, is this O.K.?
#100
Former Vendor
Thanks Hank
Thanks Hank
In direct sunlight you might see soap dry up, I would keep a stream of new foam on it as possible. Just mist every panel or two to keep damp. And yes you can store the extra as wanted.
