best wax or polish for white car
whats the best wax to use , it seems it's tough to remove the wax on white cars , is there some polish or wax's out there for light colors , that makes it easy to see ????
Everything I've tried on white is the ~same.....either a very light haze (which you have to look at angles, at) or virtually no indication at all (except a streak......less than consistent finish).
I have bright yellow, as well. Similar, just not quite as difficult.
One of the suggestions has been to use a relatively high output halogen work light/similar to illuminate your work.
Hope others have good answers. Look forward to them.
See ya.
See ya.
Satin Gloss Wax, great stuff.
Nearly all waxes suck in terms of visibility on a white car. My wax of choice at the moment is NXT 2.0. Yes it's a PITA to see where it has already been applied and tough to see when removing, but there's not too much you can do about it. I think I may eventually try that black colored wax they recommend for the ZR1 carbon if it's easier to see.
