Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
How do I go about removing the paint...
Old 10-15-2009, 09:25 PM
ROCKnROLL
Veteran
Support Corvetteforum!
ROCKnROLL's Avatar
Default How do I go about removing the paint...
used to paint the lines on the streets from the car?
My girlfriend (last time she drives it) drove on some freshly painted lines. It's on the body and the tires, passenger side only thank goodness.
Old 10-16-2009, 07:17 AM
Sleper
Sleper's Avatar
I would try some detailing clay. Its purpose is to remove overspary so if not too thick it probably will work. Tires? Good luck
Old 10-21-2009, 03:54 PM
blackmachdown
blackmachdown's Avatar
this from Kevin Brown on the Meguiars forums (dont hold me responsible for any damge lol):
If the paint is stuck to non-painted plastic (textured or smooth), it'll eventually loosen up due to expansion/contraction, oxidation, or out-gassing of the plastic. In other words, it'll eventually come off. Sometimes, use of a pressure washer will help things along. Applied liberally, M40 Vinyl/Rubber Cleaner & Conditioner will help to weaken the bond.
If the paint-blob is stuck to automotive PAINT, and the paint-blob is thick (and nothing in the chemical realm works)... Use a plastic razor blade (or a brand new putty knife, taped with masking tape) to push against the paint-blob. Again, liberal use of the M40 will help. This method is a long-shot, but give it a try.
If neither of these methods work, this one will:
Oh boy, I can hear the screams in protest of this recommendation already)...
1. Remove loose contamination (pretty obvious).
2. Wax the area with the hardest wax you can find (a paste carnauba works well).
3. Let haze, then wipe off excess residue.
4. Use a new razor blade. Rub the blade-edge across some rough leather (like the backside of a belt). The motion should be as if you were painting with a paint brush... Back and forth. This will fine-hone the blade.
Now, gently push the blade (at an appropriately slim angle) against the paint-blob, doing your best to avoid gouging the car paint (duh).
The wax coat is a barrier, and will allow the razor to ride upon it. Sometimes you'll notice the wax being scraped away. If that's the case. re-apply and repeat the process.
I've used this process dozens of times. A few times I did 'scrape' away a little paint, but it was not very noticeable.
BIG recommendation that you get the feel for the razor on a junk panel before you make the attempt on your ride.
FYI...
Before there was such a thing as over-spray clay, a company used this method (with huge success) to remove paint overspray from vehicles (primarily for insurance companies).
I used the method a couple of times to remove overspray, but it was too freaky for me!
Old 10-21-2009, 04:40 PM
JoshVette
JoshVette's Avatar
Try some 3M adhesive remover or goo gone after you clay it.
Josh
Old 10-21-2009, 07:15 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
I too suggest claying first and 3M Wax and Adhesive Remover as necessary. Always tread lightly on trim but most the time a little elbow grease will help.
To How do I go about removing the paint...
Quick Reply: How do I go about removing the paint...
