Leather seat care
Former Vendor
I might suggest staying away from shiny which is often silicones. Use a good safe leather protectant like LeatherMasters and you have a nice matte surface and protection designed for the finished leather used in almost all automotive settings.
Awesome thread bump. Hopefully, the OP conditioned his leather 6+ years ago.
I have a 2003 with 10,000 miles the leather looked terrible at 5,000 miles when I bought it, I tried Lexol, Zaino, Leatherique, when I called Lexol about what to use on my car they said they could not help me, So I decided to try the Leatherique I emailed & they said their product would work fine for my car, I even recently did another application & left the car out in the sun with plastic bags on the seats to help the product absorb into the leather with negative results. the picture below is Leatherique on the 1st time where I was testing it & let it sit for 24hrs & as you can see nothing was absorbed into the leather. Finished leather as stated above has a coating on it, that is what causes a lot of these products to just sit on the surface. So far nothing does it for me, I have some Lexol Vinylex I may try that next, I also will look into the Leather Masters, just being realistic.
I have a friend who has a 1976 he bought new, 38,000 miles, deluxe leather interior, & has been using Lexol for leather since new & his seats are outstanding.
I also did not realize this thread was from 2012
FYRARMS (08-30-2018)
St. Jude Donor '09
I would have to agree with you, I will be looking to try products in that category.
St. Jude Donor '09
It brings the oils and dirt to the surface to be cleaned off with the second step, Prestine Clean.....
Its a two step deal....
https://www.google.com/url?sa=t&rct=...psK8BDE6g-fKm8
It should plump up the surface and have a drier look, not shiny.....
Leatherique isnt designed to soak in.....
Like a fine face cream, Leatherique Rejuvenator Oil seeps into the skin and hydrates!
See bold underlined in the instructions.
Leatherique How To Instructions
HOW TO REJUVENATE YOUR LEATHER INTERIOR AND ALL ITEMS CRAFTED OF FINE LEATHERRejuvenating your car interior or any item made with fine quality leather is an easy process. Please carefully read directions before beginning application. Use protective gloves and eyewear. Step 1.
Vacuum the surface of the upholstered piece or interior well or use a soft brush to remove large particles of dirt, paying particular attention to seams, folds, and cracks. Step 2.
Apply the Rejuvenator Oil liberally (about 4 oz. per seat) with a Sponge Brush or your hands; massaging the oil well into all the surfaces and natural folds of the leather, this puts natural ingredients, not harsh cleaner, back into the leather and forces out dirt. You may also use a soft sea sponge, or a soft paint type brush. One of our Rolls Royce friends, Chuck Hull of Simi Valley, California suggests a spray bottle, which can be purchased at the local home center. Also apply the Rejuvenator Oil liberally nearer the stitched areas as the conditioner will be able to migrate laterally well into the hide. Park the car in the sun with the windows rolled up to create a “steam room” for as long as practical, several hours or a day. (Allow the oil to be absorbed into the fibrous side of the leather before putting the top down in a convertible.) Direct sun is the worst enemy of any automobile interior or home upholstery. Do not place home or office leather upholstery in direct sun. For “cardboard hard” leather, several applications will be necessary. Patience will be rewarded with good results. Step 3.
After the ph correct proteins and collagens from the Rejuvenator Oil have permeated back into the pours and fibers of the leather, strengthening and nourishing them, the surface may be tacky, sticky, gritty, or have a white haze. This is simply the dirt, grime, air pollution, perspiration, salts and other toxins that have floated out of the leather to the surface. Apply Prestine Clean by putting it in a Spray Bottle then wipe off with a SOFT lint free cloth. For tough dirt or vinyl or vinyl tops, brush the cleaner into the grain of the leather or vinyl with a soft bath brush or toothbrush. Let stand for a few minutes, usually by the time you are done with the next piece, and wipe the surface with a soft cloth Your car or upholstered leather piece will appreciate the “face lift” and will have the new leather smell restored. Prestine Clean will not remove the conditioner permeated into the leather. This process may be used on MB Tex vinyl areas to soften and condition. Even flexibility on rubber window trim can be maintained with Prestine Clean. LEATHER FACTSWe strongly advise against saddle soap, as it has been known to remove the dye from the leather. Avoid products that contain petroleum or mineral oils, as they cause leather fibers to rot prematurely. Our cleaner and conditioner have a capillary action. The proteins, cleaners, and conditioners find their way deep into the pores of the leather and force out the dirt, perspiration, air pollution, unnecessary oils, and other toxins that destroy the fibers of the leather, destroying its strength and flexibility, and causing it to deteriorate. For tough, heavier stains, we do make leather cleaner to remove the stain from the surface of the leather. The remainder of the stain will need to be “floated” out of the leather with Rejuvenator Oil. Badly stained surfaces probably need to be re-dyed.
Key Benefits
- Leather is conditioned & cleaned safely, easily, and gently. No hard scrubbing or harsh chemicals.
- Because there are no petroleum or mineral oil fillers of any type in the Rejuvenator Oil, any residual remains in the fibers, continuing to nourish the leather itself for months. Don't forget keeping leather healthy and flexible is what extends its life and makes it more beautiful.
- This is absolutely "Simply the Best" way to care for your leather, used by museums, collectors, restorers, decorators, and auto enthusiasts World Wide.
FYRARMS (09-05-2018)
