Detailed: My TR 2002 Z06
I had an empty garage for a week so i figured it was a good time to polish the z06. My plan of attack was only a 1 step finishing polish to bring the shine back to the paint. My focus was not swirl removal but i ended up removing a good bit of the swirls. I wasnt expecting to do so, so i didnt take pictures of that process plus my batteries died shortly after i started paint correcting.lol
This is how the car started off after i pulled it out of my storage unit
First plan of attack was to clean the wheels. My go too wheel cleaner is Sonax. Smells HORRIBLE but gets the job done almost effortlessly
I let it dwell for almost a minute then all i did was rinse no agitation and it left the wheel about 95% clean. This stuff performs time and time again. This is just after rinsing
Then i addressed the barrel part of the wheels. I dont have the tools to remove the wheels so i had to use a daytona wheel brush.
Then i addressed the brake calipers with another favorite of mine. p21s Total auto wash(TAW). Smells VERY GOOD may i add.
Next i wanted to remove the old tire shine(303 trim protectant) from the tires so i used Megs All Purpose cleaner from there detailing line. Warning do not breath in while spraying...dont ask me why i know.lol
The next few pics are the finished product of other 3 wheels with the previous steps
Now on to addressing the paint. I started out with my glimour foam gun. My solution consisted of 5oz of poorboys soap and 3oz of Megs All Purpose cleaner to help strip whats left of the LSP.Then went with the 2 bucket system with grit gaurds with CG Citrus wash and clear with a strong mix again to strip any remans of LSP.
Then i rinsed the car off and brought out a new product i just recently purhcased called Tar X. It worked very well and removed all the tax spots in just 1 application.
I then dried the car off and pulled it in the garage as the sky got very dark. I hate clay baring a car but i felt it was necessary since i havent done it since last year. My go to clay is Megs mild grade clay and i used Optimum no rinse as my clay lube. To my surpise i had little to no contaminants at all on the paint. I was very shocked.
Then i went on to use meguairs 205 with my flex Dual action supporting a lake country white pad to attact the paint. My first pass i used a tiny bit to much product but had very little dusting through out the process even with the high humidity. I have used m205 a few times and im learning the right amount of product to use and its getting easier to apply/correct/remove the more i use it.
My battery on my DSLR died right after my first few passes so i put the battery on charge and it wasnt ready untill i put the LSP on. I wasnt really looking for much correction. The vehicle does have light-moderate swirling but i was more concerned of finishing the paint and making it more bright which is what i achieved.
Now onto the best part and the whole reason why i was cleaning the paint to begin with was to apply my newly aquired Raceglaze 55. This stuff is very soft and all i had to do was dab the applicator pad once-twice and it coated it very quickly and easily. It went on very smooth and i was able to level it out on a panel very quickly. It also smells very good as well. The directions say wait an hour before a 2nd coat is applied. I waited a day and this is the end results.
dcarr (08-14-2020)
Good work, looks super.
Very nice! Love the color. What wash mitt is that you're using?
Not trying to tell you what you did was wrong by any means and I hope you don't take offense, but you should consider trying 1 product that can clean your wheels, tires and calipers all in one. It will save time and probably some $$ too.
Former Vendor
nice detailing sessions and the results are notable. I recently started using Tar-X also and really like the product. I often wondered about the RaceGlaze waxes and glad to hear they work as advertised. Nice work !!
I have read in the past that Raceglaze 55 is the same thing or very similar to Vics Red. Only thing when i did a little research i found that Vics red only lasts the typical 2-3 months where i read in more then once case Raceglaze 55 lasting up to 6 months. But lets face it the 95% of the final finish is prep. The ever so popular topic "this wax looks better then another" has been disputed many times before. Do i see a difference yes but is it party that i want to believe there is?Who knows? longevity is what made me lean toward Raceglaze 55 and its ease of use.
Wash Mitt would be from Raceglaze. As far as a all in one wheel,tire, caliper cleaner. I have yet to find a wheel cleaner that works as well as Sonax (besides Meguiars Wheel Bright). It does not lift dirt/tire shine off the tire very well. I dont want to use all purpose cleaner on the wheels and calipers because its a little harsh. So to answer your question to get the results that i want i use more then one product. That process i dont use every time i wash my car. My wheels typically just get washed with soap and water but when i apply wheel wax i will do a more thorough cleaning.
That looks mint!! I like 205 as well! Very nice "mild" cleaner. I'm in need of a good take down on my '04 twin to yours. Hasn't been buffed or anything since July 2011. Zaino is still holding up
Beautiful job on your car!!
Nice choice in color. If you plan to take it further, just throw on some gloss black mesh stingray wheels (don't know what they're called but they look like the z06 ones).
I am sure if he wanted to install played-out black replica wheels, he would have done it when he made this thread 8 years ago.
Woopz I meant to reply to another thread but I guess these connect at the bottom lol. Wow I recognize your username from Supraforums. Flashback from 15 years ago.
Moderator
Received 3,747 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
BudgetPlan1 (08-13-2020)
