Brinkmann Maxfire Dual Xenon Spotlight
For around $30-$35 is the juice worth the squeeze? In direct sunlight, it's easy to see swirl marks on my LMB paint. However, I wouldn't do paint correction out in the sun if it can be avoided. I was thinking about this last week when I attempted my first paint correction. I will be going round two either this weekend or the following week, taking more time and using a more abrasive compound and pad. What I was thinking about was using some type of lighting that will help me see the imperfections as I am working on them.
This light seems like it'll do the trick but I wanted to see what other tips/products people are using. I do have two sets of overhanging light fixtures in my garage, however, I'm not sure if I change out the bulbs to florescent (if that's the correct type) if they'll produce enough light during the day with the garage doors open.
Well, as I'm reading more reviews about this light it appears its notorious for not holding a charge for very long. And, it seems that if you don't use it for months at a time, the battery completely drains and won't recharge.
Any other thoughts or suggestions? Would using an LED setup work better?
Former Vendor
3D also offers a AA powered dual light Brinkman that can hold a charge up to a 85 minute with continuous run time.
http://www.3dproducts.com/Brinkman-Sunlight.html
Interesting. I didn't realize you could polish in the sun. I always assumed the compounds would cake up or dry on the paint pretty quickly.
Its my understanding that the current paint correction polishes I have now can also be used in the sun, too.
I had no luck with the Brinkman model. I couldn't get the charge to last no matter how long it was pluged in. I went with a 3W LED from Griot's Garage (#47990). It has worked great with no problems.
Former Vendor
Having worked for years detailing in the hot S. Florida sun, I have a good understanding of what works and what doesn't. Please let me know what products you are using?
One of the key elements behind 3D/HD's proprietary formulas that allow them to be used in direct sun is their use of special amino-functional-silicone-fluid. This is found in all their polishing compounds and paint sealers. Another benefit behind this technology and its symmetry is that there will never be any bonding issues between the line. So many times you hear detailers suggesting to strip the finish prior to sealing. Not with this line.
I am using the Adam's line of swirl removal polishes and machine sealant, all which they stated can be used in the sun. My experience with the sun is based on doing hand waxes with carnuba based waxes many years ago and having it back into the paint. This time around, is my first attempt to do paint correction with a DA and I did get some dusting. However, after watching some other video's and browsing various forums, I believe I simply used too much compound after priming the pads and was not related to the sun or heat.
Former Vendor
You can certainly purchase a Sun Gun at several hundred dollars, but for a reasonable price you can purchase 1 of 2 Brinkmann offerings. I have one thats on the charger when not in use and it gives enough time to polish a car provided you dont leave it on the entire time. I find the original a big brighter, but the newer swivel head model able to hit panels off angle which helps to track swirls and their removals.
Former Vendor
Think about what you're doing.......you're spreading an oil mixed with abrasives over your paint, who's temperature can vary based on outside temp and color. What is critical is that you pay close attention to how your combo is working, how it is removing from the surface, if it's dusting, if it's clumping or if it's not producing good/even coverage on the surface area. This is when you adjust the amount used, speed and surface area to find a happy medium if possible.
Many companies don't use sun friendly components in their products thus performance can be greatly affected by it. 3D OTOH, being in California & Florida tends to cater their products to mobile detailers in hotter climates where they know a product is required to be used in these delicate working environments. Other companies like 3M, Menzerna and Meg's tend to focus many of their offerings to "shop" environments where temps are much more consistence.
