Black wheels
Black wheels
I love my Centennial 2012 but keep the wheels clean is a little aggravating
Cleaned wheels thoroughly yesterday and used Armor All protectant, 38 miles later the brake dust was pretty bad.
Anyone using a method to clean and preserve black wheels, short of pad replacement?
Thanks in advance.
Thanks in advance.
Former Vendor
ceramic pads will be suggested most often ...
As far as cleaning wheels, you need to use the proper cleaning supplies and do them more often if you choose to not change the pads. You can use products like Rejex to protect them and cut down on the cleanups a bit, but there is no miracle product that alleviates the brake dust your noting.
Dump the pads your using and go ceramic. I'm running a bbk with gloss black wheels and have zero issues with brake dust - and the brakes are put through the paces.
My wheel mfg'r said only light soap and water for cleaning, any other products would void the warranty - and it seems to work real well.
http://
http://
Former Vendor
http://
http://
Often I find you need to use it only occassionally and most the time using a wheel sealant (Optimums Opti-seal, Blackfire Crystal Seal) will help protect and then using car wash for several washes. Always remember to clean the barrels too !
Former Vendor
Thanks in advance.
Thanks in advance.
Also, if you're maintaining them on a regular basis, the only thing you'll need to clean them with is just normal car soap and water. When you use harm chemicals, it will eat any protection you apply.
