Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Stains on the exterior. Need Help..
Old 03-01-2014, 01:03 PM
ag82
2nd Gear
ag82's Avatar
Default Stains on the exterior. Need Help..
Hello I have recently seen these stains ( pictures attached ) which I am not able remove if someone can help me that will be great. Its on the outside paint.. I have tried Water, soap, vinegar, baking soda.. I have read this forum and it looks maybe like hard water stains but not sure.. Any input from people will really help me..
Old 03-01-2014, 03:59 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
looks like tape residue ??? Is it sticky ???
Generally you would consider using an adhesive remover (if sticky), then moving to a paint cleansing lotion (which is a chemical paint cleaner) and then onto polishing (abrasive) as needed. If its hard water, several companies make water spot removers that should help also.
Old 03-01-2014, 06:59 PM
ag82
2nd Gear
ag82's Avatar
No it is not sticky.. when you rub your hand over it, feels something on top of the paint, but it would not come out. I tried water, soap and even vinegar.... So I dont think it will be tape residue.. I was hinking it would be water spots but not sure.. and dont they generally go away with vinegar solution..
Can I get any water spot remover in Walmart ?
Old 03-03-2014, 03:12 PM
envyz06
envyz06's Avatar
Looks like duct tape residue to me. I would try 3M adheasive remover, if that doesnt work you most likely going to have to have it buffed off as long as it is on top of the paint.
Old 03-05-2014, 12:52 PM
PCMusicGuy
PCMusicGuy's Avatar
I would try clay bar if you haven't already. If that doesn't touch it, bring it to a paint and body shop. They should be able to wet sand it away.
Old 03-09-2014, 09:30 PM
chad3113
chad3113's Avatar
Take a closeup shot of a few angles of it. Are you sure it is sitting on top of the paint?
Old 03-10-2014, 03:00 PM
ebf2k
ebf2k's Avatar
St. Jude Donor '12-'13-14
Did you ever get this fixed?
To Stains on the exterior. Need Help..
Quick Reply: Stains on the exterior. Need Help..
