Wheel Care
Wheel Care
What do the detailing gurus recommend for:
1. Cleaning / brightening unfinished aluminum wheel barrels
2. Polishing / protecting chrome wheel faces
Thanks in advance.
BIGMAC
Thanks in advance.
BIGMAC
Former Vendor
I will NEVER again buy uncoated high polished wheels. I have tried all sorts of metal polishes, nubs, and tools. The challenge is that that type of material is constantly in a state of decay. They are literally oxidizing in the environment. What I did find is that I polished them well and immediately applied G-techniqs Wheel Armor Coating. It was an amazing product and the only reason I never had my Iforged Wheels replaced.
Chrome is quite durable and when kept up, is quite durable. I would suggest Griots Chrome Wheel Cleaner. You can use chrome wheel polish as desired. I would then also coat them and G-Techniq Wheel Armor works well. The main hint around chrome face wheels ... try to avoid long term water and brake pad material exposure. The coating will help against that, and best of all make cleanup quicker. Often times, only car soap and water is needed.
http://www.autogeek.net/gtechniq-c5-wheel-armor.html
As mine is not driven in rain, I just wipe mine down with Invisible Glass and put a coat of wax on each week. After 4 years they still look new
Former Vendor
If you choose Wolfgang, just test in a small spot on barrel first. I suspect it will work equally well.
I have Wolfgang Uber Coating on my daily driver and the high-polished/coated wheels. Love it ... but have not heard or used on uncoated wheels. Now I did apply G-Techniq Armor to the uncoated Iforged Wheels and would NOT hesitate to use it again.
Thanks Killer wheels, I appreciate the follow up.
Killrwheels@Autogeek (12-25-2016)
http://www.loctiteproducts.com/p/s_t...inum-Jelly.htm
...but I am having trouble getting it plus I am wondering if there is a better product out there.
BIGMAC
I appreciate the replies but I am really looking for a product to clean and brighten the rough finish un-coated aluminum wheel barrel. The product needs to be strong enough to take care of the oxidation and pitting but not damage the chrome face of the wheel. I have been using Loctite Aluminum Jelly:
BIGMAC
BIGMAC
Mothers also has a more aggressive polish and ball, the PowerMetal Scratch Remover and PowerBall MiniMD which can cut a lot more, and should be followed with
For better clarity on what you're asking, perhaps some photos of both the front and back, and details on the wheel spec would be helpful -- year/model or brand/model of wheel.
My assumption has been that factory wheels are painted in the backside/barrel, yes?
If it's an aftermarket wheel, it could be almost anything, finish-wise.
The jelly products in the past have tended to be acidic, but their jelly formula helps control where you put them and avoids getting them on surfaces which may be adversely affected by them. When it says it's a "polish" it's really the acid etching into the surface and removing the surface level of the oxidation, but it won't remove pits (however it may make them less visible.
Certainly follow with one of the wheel protection products discussed above.
BIGMAC
Here are pics of what I am looking to improve. The wheels are OEM 2008 22" Escalade and OEM 1997-1999 C5 "Wagon Wheels" with aftermarket chrome plating on the face. Both are unpainted unfinished aluminum on the barrel. I am trying to take the lazy way by improving the finish without taking them off or using a polish.
BIGMAC
BIGMAC
There is likely no "lazy way" for this.
I think your only "lazy way" choices are either an aluminum wheel cleaner or some sort of strong "aluminum brightener" product. Certainly worth a try. The jelly product would be in that latter category. Neither will remove the pitting, but it should make it less obvious.
Seems odd they did not coat the backside of the wheels.
But to get rid of that pitting for sure, I think you'd have to do a sand and polish.
I have noticed that many most OEMs seem to paint the backside of their chrome wheels a discrete grey color, and that may be your best choice if one of the above techniques does not work to your satisfaction.
I'd thoroughly clean the barrels, paint them black of grey and them apply a paint sealant or coating. The paint will fill in the smaller pitting and the flat/satin finish will tend to obscure any pitting that remains.
BIGMAC
BIGMAC
