Need advise to remove dried wax
My Daughter recently purchased a 2016 Chevy Traverse. The previous owner was not careful when applying wax. As a result there are several areas where they got the wax on the black molding. Do any of you have a recommendation on a product that would remove this?
I believe that auto geek has a couple of products that will do the trick. You can also use creamy peanut butter. The enzymes in the peanut butter will dissolve the wax build up. After your done you can make yourself a peanut butter sandwich.
Thanks for the advise.
McKees 37 wax remover (from ag)
Peanut butter
Peanut butter
ronkh57 (05-24-2017)
Pro Mechanic
Received 3,952 Likes
Yep, peanut butter.
Mothers makes a trim cleaner that will remove even NuFinish from most textured plastic: Back-to-Black Heavy Duty Trim & Plastic Cleaner -- it's in a box with a brush, available at the major auto parts stores.
Foam block applicator or MF rag with a little VRT on to the rubber or the targa seal and your done.
