How to Create the Ultimate Corvette Garage
CorvetteForum Editor
by Thomas Mabson
It's simple, having a bare concrete floor (especially with cracks and stains) and non-decorated walls in your garage is not good enough for your prized Corvette. See how you can turn your garage into a Corvette palace inside.
by Thomas Mabson
dont gas yourself
If you are lucky enough to be building your garage new (I tore my old building down and spent two years building a new one) you can put radiant heat tubing in the new slab. That is what I did - I made a heating system with a high capacity water heater filled with a water/glycol mix. Works like a charm! If you open the doors to take a car out, five minutes later the space is back to temperature due to the thermal inertia of the concrete slab. Radiant does take some time to heat up, so I let the radiant keep the garage at 55 degrees, and when I need a quick shot of heat i use the wall mounted fan forced heater. It feels real good to be on a blanket on the floor working on your car with warmth radiating upward....
doublenut9 (08-06-2017)
