Sealant on clear bra
my guy said not to apply any wax or sealant to it, Ive been using Adams Clear Bra Polish, but they dont make it anymore. Id head over to autogeek and use a dedicated product for clear bra's
That's a very odd thing for an installer to say. I get the no wax part, but sealants are ok.
Supporting Vendor
Ppf
Certainly. Applying a sealant, wax, or ceramic coating can be beneficial and make the film even easier to clean. Just be sure to avoid any and all products that contain any petroleum distillates such as naphtha or kerosene as these may discolor the film over time.
JrRifleCoach (11-02-2017)
Thanks to all for your responses, and and I must say my installer just completed Xpel clear bra install on my recently purchased car (daily driver) and wow, I like it so much that I am planning on replacing the existing 3M/Venture shield bra from my other car with Xpel. I am concerned with the removal of the 3M/Venture Shield bra over the factory non painted stripes, not sure the stripes will pull off with the bra removal, bra age is about 10 years old. Any recommendations (other than patience and the use of a steamer or a heat gun?). Thanks!
XPEL (10-25-2017)
Supporting Vendor
Xpel
On removing the old film, you're on the right track. Let the car sit in the sun to get hot, then use a steamer to use as little stress on the adhesive as possible. This will help it come up without leaving much residue behind. Also, be sure to pull off at the correct angle. A graphic has been attached to illustrate this process.
Hope this info helps, let us know if we can answer any other questions. Thanks again for your support!
XPEL (10-26-2017)
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
I've used Zaino products over top of the PPF on my vehicles for several years now, basically treat it the same as on the rest of the paint on them!
I'm new to this. I have a GS on order.
I plan to have a clear bra installed.
Should I ceramic coat the paint first? Add any additional protection that will be under the clear bra?
Outside of being clean does a brand new car need additional polish before the ceramic coat?
Is it safe to polish a factory fresh car or is there a suggested time before polish and Clear bra so the paint hardens completely?
Supporting Vendor
Step By Step
Congrats on the GS! We hope you post pictures here once it arrives. We've answered your questions below.
No, absolutely not. If you are going to do paint protection film and a ceramic coating, be sure to do the actual clear bra film FIRST, then have the ceramic coating applied. You do not need any additional protection UNDER the clear bra.
If you were just going to do ceramic coating then yes, you would need to get paint correction. If you're doing paint protection film clear bra (which we would highly recommend doing) then you don't need major paint correction as the films adhesive is going to fill in and essentially mask any light scratches or swirl marks. If there are pretty significant scratches then you would want to get those buffed out before paint protection film or ceramic coating installation.
On the majority of cars, once they're delivered to a dealership, you are good to go. We have applied paint protection film hours after cars have been unloaded off of the trailer.
Paulzy (12-04-2018)
