Is ceramic coating worth it?
I'm thinking of taking my C6 to get ceramic coated. It's more on expensive side the 2 places I called I got quotes for 1200-2000 depending on what I want. Does it really protect the car like they say? For the same amount I can get the car wrapped.
Coating for $2K !!!
Wow, you could get the whole front end and more wrapped with PPF that is self healing and have actual real protection from rock chips and such....
Coating won't protect from rock chips and the coating itself will swirl and scratch so....
I am with Joshvette, the front end in PPF, is the ticket, the rest of the car in Ceramic is awesome. As a pro detailer that has dealt with both, You cannot beat PPF for the bumper, hood and mirrors. Ceramics(aka the well know names, Ceramic Pro. Kamikaze and Feynlabs) and PPF it is the way to go on the rest of the car
I just finished 2 of my vehicles in the Kamikaze product. One of them is a daily driver and the other is my Z06: rarely driven. I was looking for something to provide the finish, the look, and the protection and switched from another well known product on this forum. I only have 1 month on the coatings, but the look and finish is incredible. Very happy to have a product, Kamikaze ISM, that also protects the textured black plastic so many vehicles have nowdays. No report on longevity, yet, but the DD took a 1500 mile round trip with heavy bug hits on front and it came right off. The little dirt that was able to stick to it also washed off easy. Good start.
Oh, I was quoted over 2K for both the vehicles I did myself: each!!! I know there is a difference between pro and home user in the products, but I was able to add some new products to my home detailing cabinet AND coat 2 vehicles for less than the shop would have.
Take your time. Prep is everything. Was ABSOLUTELY worth it, so far.
The following 2 users liked this post by WhiteDiamond:
BudgetPlan1 (05-07-2018),
Grzldvt1 (05-07-2018)
I have a question concerning the ceramic coatings. If after applying the ceramic and later the surface begins to show some lite swirling and holograms can you re apply the ceramic coating to eliminate the imperfections? It would be a shame to strip everything start the process all over again. Would a clear wrap with self healing be a better choice for a weekend driver?
Needs to be polished and coated or coating glaze applied.
cmonkey713 (05-07-2018)
I have all the products on a car, that I buffed to a pristine state. Not a swirl mark or scratch on it 6 months later and I have washed it at least 20 times since the application as a test.
It is still as stunning as the day I installed the products.
I have had customers get keyed, and that takes a light buffing with a very light compound. I will then recoat the surface I buffed.
cmonkey713 (05-09-2018)
wife's daily driver - black - when new put Kamikaze on it - wash every week, leaf blower to dry, and then quick detail - still no swirl marks
but I did re-coat it after two years
will do it again - every two years - keeps it easy to clean
It Must be completely removed
But there is a "way" to properly prep a vette for coating ?!?!?!?!?!
Please please please describe.....
Proper prep, is the following at my shop:
Washing and Claying the finish.
Paint correction - removing the swirls and scratches on the paint surface. In my shop it ranges from 3 hours to 48 hours depending on how bad the paint is. You do not want to lock in scratches and swirls under a coating. I will always request to see the car before I do any estimate. As I have seen on this forum, I have been told "My Black car has no swirls or scratches" only to find it is a total mess.
Then you have to clean the surface oils and dust using a surface prep product.
Once that is done you are ready to apply.
I am a bit baffled by the comment about proper preparation prevents marring and micro scratches, since these are surface issues versus bonding issues. In my experience marring and micro scratches come from a lower end product that allows the surface to be scratched.
I'm also going to have my car ceramic coated next weekend. My neighbor has his Maserati done from this auto detailer and it looks like glass. different packages, different pricing. PFF is or can be pretty expensive, another neighbor has a 2017 and had the car paint corrected first, then the film put on most of the car, $4000! I'm going to get this "silver" package which supposedly last for 5 years, but they also charge for "paint correction" to remove swirl marks and light scratches first. The paint correction is $350, the ceramic coating is $595.
A local shop is running a special till June 5th 1 step paint correction, gyeon can coat ceramic coating, light interior detailing for 350. He said he can do 2 coats of the gyeon for an extra 50.
Received 1,031 Likes
St. Jude Donor '09-'10
Another plus is the easy application so you can pick up a can for around $45 and refresh as you like. Vid below shows application ease, plenty more on YouTube
CanCoat:
CanCoat:
