67 paint detailing
67 paint detailing
Good evening ,
It’s been a few years since my last thorough paint detailing.
At that time I clayed the car and used Menerza products with a porter cable
orbit sander.
I lost touch of new products.
The car has an older ( 80’s) enamel paint job in decent
shape. Needs to be cleaned up.
Can someone steer me to products to give my paint
the WOW it once had.
thx, Brian
orbit sander.
thx, Brian
Good evening ,
orbit sander.
thx, Brian
orbit sander.
thx, Brian
Good evening ,
orbit sander.
thx, Brian
orbit sander.
thx, Brian
With a PC, I would get the following:
BIG POINT!! Pushing a buffer around at high speed, just pushes product around and does not allow it to do it's job. Moving a buffer at speed is counterproductive. It should move along at a snails pace. Let the product spend some time on each section.
If the paint is micro marred/light swirls - Zaino's ZPC will produce an incredible shine, the best I have ever seen with 4 Rupes Yellow Pads - One for the hood, roof, and rear, One for the left side, one for the right side, and an extra one to have in reserve if the pads get exceptionally dirty.
Run the PC, just a notch or two above 4 and work ZPC until it is almost dry. It is what they call a diminishing compound. It starts out as an aggressive compund(This is a very relative term, as it is mild compared to many products), then breaks down as you work it and will polish up the surface to a brilliant shine.
If the paint is really beat up, then go with Jescar Cutting Compound and 4 Meguiars Microfiber Cutting Pads
You can get an incredible shine from Jescar using the proper technique.
Proper Technique for Jescar Using a Meguairs cutting pad, 4 pea sized drop on each corner, run it at 4, with some pressure, but not too much. I do 4 passes over an area 2' x 2' is the recommended area, so I come as close as I can to that. The 4 passes are one horizontal, or vertical, depending on the panel, then the opposite direction, rotating for 3 more passes. Here is the key... then I do 2 more passes with very little pressure at all. That will polish up the surface. Microfiber pads have a tendency to leave microscopic scratches behind that detract every so slightly the finish. Very, very light pressure will improve the final finish. Same speed goes for Jescar, snails pace.
