Proper car wash
Proper car wash
Gentlemen, I have a question as my normal way of washing my car has needed to change a bit.
I have now moved into a more country setting with well water and i certainly feel the need to filter the source. I know i can get a standard sediment filter and so forth but what is the feeling on using spot free filtration as well? Anyone use the CR spot free system or anything like this that can give some feedback? I do not have a lot of iron or anything crazy in my water, but wells will pull articles that i do not want to throw at my car through my mtm foam cannon.
Thoughts?
Thoughts?
I live in rural Va. and use well water to wash my Vette all the time. Our water has alot of calcium in the water which leaves white spots if left to dry. We do have a water filter but it is located in our home and before our outside faucet unfortunately. I have gotten used to using a blower and spending alot of time wiping the car down even doing that there are usually a few spots. There are several brands of cleaner for spots that seem to work pretty good. Good luck.
Received 1,872 Likes
2020 C8 of the Year Finalist - Unmodified
So as you dry it, go hit it with a spray bottle of something like I use like Adam's Detail Spray as you dry it....... takes ALL the water spots off as you dry. Just mist it on and wipe it off.
Try to wash your C7 during the cooler part of the day out of direct sunlight if possible and thoroughly drying it and you should be ok.
Thoughts?
Thoughts?
Moderator
There was another thread where a guy recommended an RV in-line filter from Walmart with water hose fittings on it. Said it works great. I'm getting one of those before I wash it again.
I use Griots waterless wash only. Have a 2014 that has not seen water in four years now.
I also have well water/septic, but saying that doesn't necessarily help the OP. Well water is all over the map as far as dissolved and non-dissolved solids (even though there should be little or none) are concerned. I'm lucky, and mine's pretty good, and as long as the year is not dry, I don't really worry about "wasting" water. It pretty much gets put back into the ground to be filtered (soil/rock) to be available again.
A hose or a good touchless wash is a DD's friend, IMO. The OP doesn't say how he drives it, as far as I could tell.
That wash and wax in a bottle stuff is great. I used it on my DD when I moved to another state for a new job and lived in an apartment while getting to know the area. Washing the car was impractical and I wasn't going to put my paint through a car wash. That car wash in a bottle was a lifesaver. I've been in my new house for almost a year now (maybe not so new anymore) and I haven't bought a garden hose, I just use the that 'waterless' wash and wax instead.
Received 5,202 Likes
"Waterless" may be fine in some settings but not where I live/drive!
ONR is sooo very versatile and you can use it as a clay lube, quick detailer, window cleaner, interior cleaner, and you can use as a no rinse wash as well obviously.
If you're considering a CR spotless, or any other filter system, I would suggest you get a TDS meter off of amazon and see how "hard" or "soft" your water is to begin with. If you have really hard water, then you will go through filters very quickly and they will be expensive.
I would avoid waterless washes, swirling can still happen.
ONR is definitely a must have for all things and yes, you can use ONR on all things.
I want a CR Spotless as well, for now I work fast.
