Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Garage floor coatings.
Old 07-13-2018, 06:58 PM
Ernest
Ernest's Avatar
Default Garage floor coatings.
Not sure if this is where I should post. Have a 3 car garage built in 2001. Time to coat the floor. I put it off for too long. Have a steel wheel engine crane and steel wheel floor jacks. What coating did you guys use. I only want to do it once and correct. looking at Ucoat it.
Old 07-14-2018, 10:55 AM
charley95
charley95's Avatar
I used garagefloorcoating.com back in 2011on my 2 stall built in 58. So far, I'm very satisfied. I use my steel wheel floor jack all the time with no damage. I made the mistake of putting the car on floor jacks that are made from angle iron. It put gouges into the surface but other than that the floor has held up very well. It's not cheap but well worth it IMHO. You'll need a floor squeegee for when it gets wet. Much better product than home center coatings.
Old 07-16-2018, 09:16 AM
hb4lthr
hb4lthr's Avatar
I used a company that provides epoxy coatings called Stronghold Floors https://www.strongholdfloors.com/. You'll have to find a similar company in your area. I am absolutely thrilled with the results.
Old 07-16-2018, 09:25 PM
chasboland
chasboland's Avatar
I had a concrete floor coating installed a few years back. It’s called POLYASPARTIC and it is amazing. It stilllooks like new after being exposed to a few salt riddled northeast winters. Granted it was pricey, but couldn’t be happier with my decision.
Old 07-16-2018, 09:35 PM
chasboland
chasboland's Avatar
Default Polyaspartic coating with flakes
Old 07-17-2018, 12:30 AM
snomuncher
snomuncher's Avatar
Default Floor Coatings
This forum contains a section that discusses the different types of coatings and different experiences with them:
https://www.garagejournal.com/forum/
I applied Epoxy-Coat with a heavy flake on the floor of my working garage in 2012 and it has held up well to steel-wheeled floor jacks, jack stands, grinding sparks, machine grit and other abuse. The only issue I've had is having to touch up a few localized areas where the epoxy lifted under tires that sat in one place for longer periods of time.
Old 07-18-2018, 01:26 AM
RedC6
RedC6's Avatar
I love racedeck, if I was doing mine right now that is what I'd be buying.
Old 07-19-2018, 11:40 AM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
If DYI the most important part is cleaning the floor, especially if it is not new concrete.Automobile tires have paraffin wax like substance that will imbed its self in the pours concrete. If the wax is not completely removed the coating will release in a year or so. It is extremely important to clean the floor with muriatic acid several times on an old concrete folly and rinse completely. Let dry for several days and then you are ready to fill expansion joints and cracks. Now you are ready to apply the coating. The floor must be clean and free of paraffin wax, oil, paint or any other material on the surface of the floor.
Old 07-20-2018, 10:29 AM
bigcypress
bigcypress's Avatar
had epoxy done a couple years ago , $6.50 sq/ft x 800 square feet . it's nice where two vettes sit but where wifes daily driver sits it has some flaws imbedded in it from stuff tires picked up . i'd tile if i did floor again .... peace
Old 07-20-2018, 10:35 AM
acroy
acroy's Avatar
Received 1,395 Likes on 840 Posts
Racedeck or just acid clean/stain/seal the concrete. Tile, epoxys etc are $$$$ and all fail in time. Spend the money on car parts
Old 07-20-2018, 03:50 PM
RedC6
RedC6's Avatar
FYI, I helped my friend install Garagetrac last weekend, which is made by Racedeck and looks just like the diamondplate racedeck tiles... and they are extremely high quality but more of an affordable version of garage tile. During installing and after installing, you couldn't tell that it was the more affordable version of Racedeck in any way. Plastic is the same, I believe the only difference is in the bottom channel of the tile (although the Garagetrac is very good the way it is).
All in all, this is what I would do for mine for the price- $2.11 a square foot. Racedeck is $3.79 a tile.
https://www.bigfloors.com/product-ca...ng/garagetrac/
I'm now figuring out how I want to do my garage and what color(s) I want to use.. it is awesome stuff.
Old 07-24-2018, 02:29 PM
ronkh57
ronkh57's Avatar
Pro Marine Supplies - Epoxy
To Garage floor coatings.
Quick Reply: Garage floor coatings.
