Whats the hot ticket for paint correction these days...
Looking for some updated advice.
I've used HD Uno Cut and various pads on my PC polisher in the past to prep for Zaino CS. This was 2013-2014.
I'm planning to do some minor polishing on my Jazz Blue Hellcat in preparation for some type of Ceramic...maybe CS, maybe Hydro Silex. I'm definitely going to give Kenotek a shot as well...
Any more current product advice or help appreciated. I searched...didn't find much specific to the prep work.
Are you looking for a a great single step product? Or are you looking to maximize the overall clarity and gloss of your hellcat with a multi step paint correction? Even though this is a Corvette Forum and GM clear coat has no similarities. Your dodge will be a great deal softer in terms of clear coat hardness and will be easier to work with and finish down.
Single Step Combination, I would recommend Shine Supply Burn Out with a light cutting pad (like a orange lake country flat pad) which is a great product for single stepping and is infused with Si02 and will leave your paint ready for a ceramic coating installation assuming you have prepped the surface correctly by removing contamination (iron, environmental fallout, and sealant)
If your wanting to maximize the depth and shine and make it all it can be I would recommend shine supply flat top compound or sonax cut max with a meguiars microfiber cutting pad or a buff and shine euro fiber cutting pad for your correction work and Carpro Essences with a orange or white lake country flat pad to polish out to high gloss. Essences is also infused with Si02 and will leave your surface prepared and ready for a ceramic coating.
In my dettiling shop I had incredible success with Jescar's Correcting Compound with the Meguiars Microfiber Cutting Pad, followed up by Zaino's ZPC and a Rupes Yellow Pad. Then used Ceramic Pro on the horizontal surface and Kamikaze Miyabe on the vertical. It was a test to see which product looked better and held on longer. So far Kamikaze's Miyabe has hands down won the battle for looks, between those two.
Now, I am also a Feynlabe installer which came after Ceramic Pro and Kamikaze,and that product is simply beats the heck out of both of them.
But back to your point, the Meguiars Microfiber Cutting Pad leaves behind microscopic swirls that very faintly detract from the finish. Sonax, or ZPC with the Rupes Yellow Foam Pad produces an incredible gloss.
My shop was known for more Best In Show car that I can count, but I sold it and moved onto other things. I did my wife's metallic Red PT Cruiser as an experiment in terror with the above combinations, and can barely get out of the gas station, as so many people want to know what kind of paint is on that car
As pbreflectionsllc hints at good correction takes time and patience. It is not an exercise in speed.
Grzldvt1, I am an amatuer paint correction enthuisast.
I have been using my Porter Cable 7424 6" backing Plate.....with your suggested Meguiars Microfiber Cutting Pad
and Meg's 105 and a little 100 to remove the chips in my 2012 Grand Sport Clear Coat and the straight line scratches.
Is the Jescar's Correcting Compound that much better to justify buying it as I have new 32oz bottle of Meg's 105.
I followed the 105 with Meg;s 205 on White Lake Country Foam Pad.
Also for remaining very minor clear coat defects (chips) should I quit while Im ahead versus any grit of wet sanding
I dont have paint depth gauge. Should I buy one that is affordable (???) and then how to know how thick your clear is???
Never heard of Feynlabe before. Is it only sold direct from Mfg to ANYONE???
Do I need to buy ALL there Prep products
I'll look for other Feynlabe Reviews ????
There is no way to know how thick your clear coat is without a paint depth gage which is very expensive. There is no quick fix to defect free paint. Always start with the least aggressive approach and go more aggressive as needed. If you are not experienced in paint correction you may want to watch the videos posted on the Autogeek site and other internet sights for technique and product usage.
I think for my purposes on the Hellcat (which scratches very easily), the single stage should work nicely. Thanks again!
Here is my sons '03 Sierra - V8 with a 5-Speed stick. This was my first attempt at correction. This truck had lived in CO/KS and saw it's fair share of automatic washes. I thought it came out pretty good.
Do not get too bollixed up with all the Feynlabs products. You just need the coating product. I have used all of their products and given them feedback. While most are absolutely incredible, some are a pain in a$$ to use. Because I am an installer I see a different view. If you create an account and can get the Heal Lite, that is the way to go. Include the Leveling Aid, even if not Feynlabs product it is amazing to help remove high spots and create the perfect ceramic surface.for any product.
Having said all of that Kamikaze Miyabe available at Esoteric Car Care, is my second choice, Easy to use, you have a lot of time to correct high spots, but you don;t get the longevity that Feynlabs has.
CamarosRus (10-21-2018)
Grzldvt1, Your posts are informative..THANK YOU
I would like to buy the FENELAB product(s) during Black Friday sales weekend if possible
I need to read more and list out exactly what Im able to purchase vs the certified stuff Im unable
A friend this last week had a new RAV4 rental that had picked up significant parking lot scratches
defects.
I started out with my Megs Micro Fibre Cutting Pad and Meg's 105. While doing a good job it would not
remove all the scratch defects....after TWO sessions
I then used Megs 100 and Bingo...it removed ALL the defects within a few minutes (or less)
I surprised myself
I am NOT a pro detailer and dont want to keep buying product after product $$$$$$$$$
Which of the above mentioned polishes is most similar to MEG's 100 vs more similar to MEG's 105
defects.
I surprised myself
Received 1,031 Likes
St. Jude Donor '09-'10
Feynlab products are only available via their website which likely means no sales but I don't follow them very closely so maybe they run sales from time to time. Have a vehicle I'm watching that had their Ceramic + TopCoat applied to it in Febraury 2018. If you like a sharp, brilliant shine (a la' Zaino) it.s the product for you. As a consumer you'll likely not have access to their self-healing products but that could have changed as well.
Ive recently gotten into a little detailing, myself, and to get started, I of course went to YouTube. Because, where else can you find out how to do just about anything??
Anyway, I started following a gentleman that has a successful mobile detailing business, in Dallas. He uses many products from Menzerna, to HD Speed. And hes actually had great success with Griots more professional line, of BOSS Creams. Scott from Dallas Paint Correction and Detailing. Great videos.
Scott is my favorite, and even though he rambles a lot, he has helped me a LOT. I follow a few guys. The Forensic Detailing dude from the UK is good, and the Apex Detail guy does a lot of product versus product testing. You can waste a whole week watching these guys. LOL
Z51VetteFan (10-23-2018)
