Opinions on, or do you use, waterless car washing sprays?
I have used several according to instructions, meaning for light dirt or dust only using microfiber cloths as directed. I find it better than detail spray, even for light dust. Meguiar’s works as well as any I have tried.
I'm slowing transitioning to doing waterless more often. Our water is hard as hell and I often feel I'm doing more harm than good. It's impossible to get all of the spots off without wiping and drying multiple times. I don't drive my car in the rain and we don't have snow. It's almost exclusively dust. I'm now a believer the waterless products are better for my car.
FYRARMS (03-18-2019)
Former Vendor
I have detailed several of the Corvette executives C7'S many times after they drove them either from Bowling Green or Detroit to PA.
I used Waterless Wash on them every time, some of them had a thousand bugs on the front clip. For those I would use more product & several WW towels.
They all turned out great and always got complements from the guys. Remember at the larger GM dealerships you can pick up Adam's products, because Adam's is the official product of the Corvette.
the kid C6 (03-19-2019)
Moderator
Received 3,747 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
I have used the waterless on the inside of my Z06/07 wheels.. really hard to reach since they are so darn deep, and usually helps. I have also used it for undercarriage... but never painted body surfaces. 3 bucket hand wash, and Griot's Speed shine in between.
#33
Former Vendor
Check out this video!
#34
I found the key to avoiding swirls, etc is to make sure you use a very deep pile micro fiber towel, make sure to pre-dampen it with your detail spray solution before you start wiping the car down and turn over often so the dirt goes into the piles. By flipping the towel over often to new "squares" and using multiple towels, there is very little chance for swirls and scratches.
But as said, if your vehicle is muddy, covered in road salts, super dirty, etc...then the soap and water is pretty much the only thing that is going to be efficient.
#35
I am adding the wash mitt that I use for my rinseless wash, It probably isn't necessary but I do a 2 bucket method, I like the mitt as it holds a lot more water.
https://www.autopia-carcare.com/micr...l#.XJOevaCQzIU
https://www.autogeek.net/rinseless-wash-mitt.html
#38
I was using the Meguires waterless carwash, but yesterday I picked up some Mothers waterless carwash. My car was a bit dusty so I used the california duster and then the mothers product, car came out great. Mothers waterless carwash is what I will be using from now on.
#39
The only time that I don't use WW is when I get caught in the rain, have mud or Winter junk on the car. I forgot to mention that the WW MF towels are key in this process.
https://youtu.be/2vCuSifHQHI
#40
I've had my 2017 GS for almost two years now (May 2017), and have never washed the car with soap and water. In addition, I've driven the car from NJ to FL and back twice. I use "waterless wash" to remove the dirt and grime after each drive and in between (As a note, I use the Novistretch bra and blue painter's tape for the nose on those long drives).
I applied Gyeon Can Coat ceramic last year and use Surf City Garage Speed Shield (Ceramic spray) about once a month while using detail spray for daily touch ups. Following is a picture of the car after the long drive and a clean up.
wmupaprmkr (01-12-2021)
