Pitted gouged aluminum wheels
Is there a way to remove this black pitting on the one rim, and the gouge on the other? Or is there a way to make it all less noticeable? Or is the solution new rims? (which seems to be cheaper than having these reconditioned)
Or something else?
Or something else?
Thanks, I will check in to local options for that. Is there any market for these if I wanted to sell them? Seems like it wouldn't be much more expensive to buy a set of aftermarket rims.
Apparently no one in my neck of the woods can refinish aluminum. They want to ship them to Indiana for $250 per rim to recondition them which is more than I could get news ones for.
Has anyone tried these aftermarket replicas? https://www.oewheelsllc.com/Corvette-Z06-Wheel-chrome
They are an aluminum alloy with chrome plate. Would you be able to mix one of these into a set of Speedline wheels or would it be obvious that it didn't match?
Rvajma (06-15-2019)
Have you done anything to them yet? I think it could polish out with a bit of elbow work.
Rvajma (06-15-2019)
I ended up applying elbow grease and they turned out ok. Used 00 steel wool and vinegar, then washed and waxed them. I know they say don't do that, but I was ready to buy a set so it was worth a try. As you can see, they look much better, although not perfect. I have read that these have a clear coat on them. If I had to guess, I'd say the black spots were in the clear coat, and I removed them without removing all the clear coat. There are a couple spots where it turned milky white, which I guess means I went through the clear coat, so I stopped. Not perfect, but I can live with it.
