View Full Version : C6 Tech/Performance
- need advice on cooling upgrades
- Question about C6 ZR1 Carbon Fiber Top.
- Heater o2 error after longtubes
- 09 Z06 Hot slow start
- What cam is the best in your opinion
- Header instal estimate
- Headlight fuse.
- Ride Height Issues on 2011 Grand Sport, 16k miles
- Z06 Brake Caliper
- Tick Clutch Cylinder?
- Tilton ST-246 twin disc clutch
- 2007 zo6 lsx, blew it up. Now looking at quick options.
- Top speed in each gear
- Rear cradle hard to fit after TT rebuild
- Installing a Z06 Muffler with NPP on a Base Model
- Strange fuel smell after spark plug change
- Troubleshoot “service vehicle soon”
- Z06 LS7 Texas-Speed Dropped valve issue
- C6 09 zr1 supercharger put on a c6 09 base model
- Cant make this up, 08 Z06
- Best radiator for 09 c6 basically stock
- Best c6 GS brake pads
- 2007 C6. No fuel pressure with pump running.
- Some oil in my MSD manifold 07 Z06
- Clutch Master Cylinder Replaced - Need Clip
- Remote Slave Cylinder Hose
- Brake Pistons won’t retract!!
- Grand Sport Dry Sump Engine Oil Cooler Function
- Difference in Power Stop brake options
- Is this wire causing my issues?
- c6 convertible top
- 1st to 4th Question
- CEL after can install????
- Front Transverse Leaf Spring
- BTR Hot cam
- 2005 T56 issues
- Comp BSR Shaft Rockers Experience
- Morimoto Headlight Install Help
- Fuel Pressure drops C6
- Engine install
- 2011 GS, evap solenoid replacement, how to reach??
- Hankook on my 2010 GS
- Unique electrical gremlin 2005
- C6 tech problems
- C6 GS exhaust recommendations
- C6 rim and tire suggestions
- Mods before adding boost to LS3?
- New Clutch? Clutch slave cylinder.
- Best Lap Joint Band Clamp?
- 2005 Corvette Gauge Cluster Stopped Working
- ZR1 Possible Misfire/TB issues, Plug Wires recommendations
- Radio install question
- C7 Seat Adapter Harness DIY?
- Air Bag Light
- '09, 87K miles, asking for tips
- Help, Rev after engaging clutch
- Ls3 gasket kit
- Z06 #4 Replica electrical issues- help!
- trouble shooting broken wire harness
- Adding exaust
- Must have modifications for supercharger
- Headers 101
- C6 ticking, is it a lifter, exhaust leak, or something worse…
- Help With U0122 and P0449 Codes After Clutch Job - Lost
- 2009 LS3 vette cam swap
- Built 6l80 vs built 4l60
- Hud not displaying.
- Z06 Mystery Cable
- Issue with 3rd gear
- Major Balancer Wobble AFTER Install
- Looking to grab a Shorai Lightweight battery, got some questions
- C6 z06 exhaust on grand sport
- Unable to reconnect steering column to rack
- 2007 Active Handling
- Battery volts drop to 10.5
- Cam Specs
- 2009 Z06 Overheating
- Performance shops in DFW?
- Ls3 oil leak
- '13 Grand Sport Conv which battery ?
- Car dies after initial start after adding mods
- '13 Grand Sport Conv DRY SUMP ?
- throttle body injector size..advice
- Dropping Rear Sway Bar - Question
- Wheels fitted
- Torque Converter
- Lowering bolt frozen. Tried everything
- Oil Consumption and Smoke on Decel C6 Z06
- ported throttle body
- Vara Ram Questions
- Power Window screwed up
- BTR Valve seal question
- LS7 Lifter Removal
- Radiator Fan Inoperative: Suggestions?
- Drops voltage
- Tires rubbing on fender
- C6 ZO6 Leaking Steering Gear
- Outer tie rod alignment
- 20% Back On Corsa Exhaust! Get Up To $504.59 Back On Corsa For C6 Models
- Vert Power Top Sticking
- Query on 421stroker 6.0 build - Expected whp?
- 114 oil pressure
- Tuning in Pittsburg Pa area
- Stuck oil pressure relief valve
- Oem Slave cylinder
- about rod clearance on LS9
- C6 a6 ls3
- Radiator leaks in C6?
- bogging and hesitation
- Right package for cam swap ls3
- Delayed Shifting
- Cam / Head help
- Another wheel/tire question
- Heater - A/C display flashes
- Magnetic Ride Vs Coilovers
- Clutch recommendations for 800rwhp
- Trouble starting
- Nw South Carolina shop
- Base vs Z51 Parking Brake
- 2012 Zo6 TT, TR6060 and diff install in 2005 c6
- Help with half shafts
- 2007 C6 Z51 Manual
- Diff Speed Sensor to Holley ECU
- (New) C6 GS Wheel & Tire Question
- Holley Terminator X Max/CAN Bus
- hight volume oil pump
- Looking to fix rattle need Part# 25778761 Cowl panel inlet
- 2012 GS rear end on a 09 base model swap
- St Patrick's Day Sale at RPI Designs - Save 10% on Most Products!
- Help! Corvette C6 2008 A6 shifter problems.
- Hooker Headers Blackheart C6 fitment
- sway bar alternatives
- LS2 timing chain backslash
- Keys not learning ....
- Columbia, SC area Tech 2
- Ls3 vs Ls2 cam
- 2009 Conv 6.2L LS3 CAN Wiring Diagram Troubleshooting
- SPAL Brushless fan wiring
- Clunky trans when cold
- Issue on install engine by the top
- Rear diff ratio question
- Header bolts or studs on LS3?
- Metallic tapping noise under moderate to heavy acceleration
- what is this and why is it leaking
- Car pulling right still… next step?
- p2714 tranny problems
- Backfiring only at idle
- New style headlamps
- No Fobs Detected - HELP!!! I've tried everything I can think of.
- Pressure in the rear end?
- Battery problems
- Adjusting height of brake pedal
- Headers
- Leaking Dewitts Radiator
- 2006 Corvette Alternator Voltage Regulator P/N?
- Tire Recommendations
- Time for a new car battery???
- C6/C5/C7 suspension technology
- Will mcleod rxt and flywheel from a c5 fit c6 ls3
- What headers are best
- c6 fans
- Camber kits - What are they and do you need one? Plus C8 Install video
- What oil to use for 2005 6spd
- Powerglide swap problem
- Looking to get a stall converter, wanted some input on some stuff
- charge faults
- 2005 LS2 low oil pressure during break in
- 2005 Corvette Electronics Acting Up
- LS lifter trays and other LS pitfalls
- Hard to get shifter through reverse gate
- C6- Headers and X pipe and Good shops (Michigan)
- How do these plugs look?
- Cam support
- P0700 p0716 help
- new fuel sending unit issue
- P0300
- ATI balancer crank snout lubricant question
- ls2 heads suggestions
- Coolant Leak Help
- Oil Pressure wont go over 40 psi
- boosted LS7 build
- Mighty Mouse and A&A Kit
- Problem speedometer gages corvette C6
- Shifter Bushing Help
- LS2 mods?
- Track Guys: Bosch ABS or Motec Traction, which one 1st?
- Air to water setups
- E85 worth it or not ??
- Easy brake fluid change on a 10 GS
- Bucking with Light to Moderate Throttle, 4th Gear at 70 MPH
- ABS Brake Bleed on Grand Sport
- Best Tuners
- P1SC charge pipe
- 2005 cooling fans not working
- Let’s guess what power I’ll make - 2013 Z06
- Testing Window Regulator/ Motor
- C6 manual knob with C7 shifter?
- C6 GS Corsa Extreme Too Loud!?
- 2005 C6 LS2 Z51 6-speed - Check Engine Light - Cylinder 1 misfire code
- Carbon to iron rotor conversion
- 2024…mild/sleeper LS7 cams that preform!
- Will short headers improve performance?
- Cai
- Happy President's Day With A Special Sale from RPI - upto 12% off & free shipping
- Another what oil to run thread - 7.1L
- Help. 2011 grand sport. Silver.
- Shock absorbers 08 base convertible
- Another door thread…gotta push twice
- Gas cap vacuum
- FCP Euro Brake Pads
- cooling fan removal
- P1SC Procharger HELP
- 2010 HVAC Control Module Replacement Video
- I'll Have Corsa Send You Up To $400 - Here's How!
- Mobil 1 Oil Filter M1-113A
- LS2 oil pickup retaining bolt size
- Rebuilding ls2
- C7 rear end swap on my c6?
- HVAC Controller from Auto and Truck Electronics
- Slave Cylinder Clip
- P0171 and P0174
- P0171 and P0174
- OBX Racing Headers
- C6 Z06 upper trim between passenger and trunk compartment removal?
- What’s the difference in these two plugs?
- 07 Z51 brakes
- DRL/front turn signal socket
- Oil Pan Stain on 2008 Corvette
- Track Day Tires for C6 Base Corvette
- HUD alternatives
- 09 Coupe overheating when stopped
- NavyCorpsmanVetteran Build Thread
- Harmonic Balancer Help LS2 2007
- Thoughts on this LS7 crankcase venting solution
- Halltech says "The Early Bee gets the Honey"
- 09' Passenger side door issue
- Options for addressing P0430 code
- Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
- High rev on cold starts - vacuum leak or tune?
- P1516 Bug .. any help with this !!
- Welcome Feb With Special Sale from RPI - upto 10% off & free shipping - Feb24 Code
- Dsx aux fuel pump on N/A car
- 2024 Forgeline and CW4L TAX/Spring Sale!!!
- C6
- Moog sway bar end links - load or no load on suspension
- 2005 Torque Tube removal with automatic
- Brake pads & rotors install question
- A4 Base Supercharged w/3.73 gears
- RPM Transmission 2005 C6 Corvette Performance Upgrade Differential
- Paddle shifter conversion
