View Full Version : C4 Parts for Sale/Wanted
- FS: Pocket Programmer EPROM burner
- AKM Interface Cable - OBDI
- F/S 1984 Hypertech Power Chip ****NEW IN BOX****
- F/S 1984-90 Corvette LeBra Front car mask***New in Box***
- WTS:NOS Outer window door seals...60.00 shipped
- F/s 84 Corvette Heads Has 51 K On Them For 100 Pluss Actual Shippin
- FS '89 full headlight assembly
- Mt Et Streets 26x11.5 15lt New
- F/S 1984 corvette Crossfire Intake Set-up..**Pics**
- C4 top/ bought wrong top!
- Wtb: Bra For C4
- WTB: 89 clutch slave cylinder
- 84-93 Seat Motor NOS
- WTB - Goodyear GSC
- wtb.Glass roof panel for a 84
- WTB: Hurst Short Throw Shifter for my 95
- WTB: 90 sport seat lumbar button cover
- FS: 13" HD cryo treated zinc plated slotted/drilled rotors
- FS: tire pressure sensor bands. $6 each.
- FS: chrome ZR1's wheels GS size/offset w tires
- Great dealings with Samc
- F/S 95 ac radiator
- exellent dealing with hurricanejames
- F/S Z51 Front And Rear Springs
- gm part#1104032 Opti-Spark Dist.
- Fs: GS calipers and Brand new Wilwood 2piece 13"rotors.
- WTB: Driver's side black carpet
- F/S 1985 Corvette
- fs: black standard seat covers
- wtb: four core radiator, or where i can get one
- Wtb 94 Sport Seats
- WTB: zf tranny ball and fork
- 84 to 87 POLISHED OEM Wheels FOR SALE
- WTB: 91 6speed ECU
- F/S Wheel Adaptors
- WTB 92/93 Cluster
- WTB:'85 targa top
- F/S: Energy Suspension Bushings (pics) - Balljoint Boots - Sway Bar Links
- wtb:C4 fuel door hinge
- AFR Competition 220cc Small Block Chevy Racing Cylinder Heads
- LT1-4 AFR Heads
- Great dealing with grinditout
- WTB front black outs
- F.s. 84 Ecu
- WTB: Fuel pressure gauge
- WTB:Phantom ABS Taillight Louvers 91-96
- F/S New GM LT1 Crate engine
- F/S LT4 Valve Springs GM Performance Part NEW in box Part Number 12551483
- FS: Factory GM VHS Owners Tape
- Fs A/c Evap Core And Case
- WTB Rollbar For Early C4!
- 58 mm Air foil needed for 96 LT4 carb
- FS-March Racing Pulley set
- Not so good dealings with gregm999 and FedEx
- FS-Prothane Total Kit
- Need C4 luggage rack
- Want to upgrade with C5 parts?
- GoodYear Eagle GSC P275 40 ZR 17 Left
- FS: Edelbrock 3860 High-Flo TPI base lower intake manifold
- FS Body Kit
- WTB Accusump Elec Valve and Oil Adapter
- Looking for an early Dana 44
- 85 Wheels and Bose Radio
- WTB-4 lug nuts for 92
- WTB - Chrome C4 exterior emblems GS or CE
- WTB-Stock Throttle Body for 90
- C4 Collectors, Misc Interior parts pakage!
- FS: BRAND NEW GM Throttle cable
- WTB.......95-96 fenders
- FS Various L98 Parts
- F/S: Two 1988/89 wheels
- trade 1.5 roller rockers for 1.6 roller rockers
- F/S Dana 36 - 2.73:1
- FS parts from an 86
- WTB 1994 - 1996 Standard Seat Buckets
- WTB: OEM Composite Valve Covers 96 LT4
- Free items in the southern LA/MS area
- FS-Polyurethane Bushings
- WTB: 1 FX3 Front Shock actuator
- FS: TPI NOS kit
- C4 Daytime Running Lights
- Parts needed for a 90 coupe
- FS: 1988 Exhaust Manifolds.
- WTB Driver Side Door Handle..
- F/S 84-90 Rear Bumper
- Parts for sale
- WTB FRONT Bracket to mount targa top
- Melling high volume high pressure 10555 oil pump/pickup
- F/S: 101 Projects for your Corvette Paperback Book
- F/S: 96 GM Service Manuals
- F/S: Hypertech Power Programmer III for 96 Automatic
- FS: Protorque Race starter
- [WTB] Evaporator Housing
- HVAC Door Clips
- F/S Rear glass w/ defroster
- F/S Kwiklift in San Antonio TX
- F/S All 4 tire pressure sensors from a 95
- FS: 1993 black sill panels and speaker covers
- FS: black/black 1993 door panels
- FS: Cyberdyne tranmission tempature gauge and sender
- FS: Single A-Pod Piller gauge mount
- FS: 8 stock LT1 Fuel injectors
- FS: Aluminum tranmission pan - 700R4 automatic
- F/S R-D Racing CAMBER-BRACE L-98 85-89 models
- WTB: 16" Sawblades(NJ Area)
- Great dealings with cmashark...
- need egr solenoid 85
- FS: Rocker panel 1996
- WTB OEM fuel regulator for a 1988
- Targa Hardtop brackets
- WTB drivers side speaker grill
- wtb 1993 zr-1 17x11 saw blades rims
- Excellent dealings with Pete Kane and his new converters !!
- brakes
- VERY used seats from 1984 C4 in Alabama
- Super Price on C4 Carpet Sets on E-Bay
- FS- Breadbox from a 1989
- Wtb Air Filter Element Cover For '95
- F/s Almost Brand New Stater
- WTB 88 Front Bumper Cover
- What is a 92 ZR1 worth??
- WTB: Camber Strut Rod Eccentric Adjusters
- WTB 85 drivers seat
- WTB knock sensor for an 84
- wts 86 rims/tires
- F/S 4 GOODYEAR GSC-EMT RUN FLATS and 96 OEM DIRECTIONALS ZERO miles
- Excellent transaction with forum member "Chatman"
- WTB: Rear Spring @ 39.9 N/mm Rate...
- WTB: BBK / Edelbrock TPI PLATE (Black)
- FS Beige Standard seats out 96 coupe
- lloking for used parts 86
- 96 Artic white targa/MagnaflowSS mufflers
- WTB: Sun visors for a 1996
- PnP LT4 intake manifold
- Wtb: 1996 Ce Speedo / Tach
- 88 TPI plenum, runners and manifold
- wanted: C4 break parts & 17 X 11 wheels
- Show me your coils / super coils High performance coils ...i want one !
- WTB 1997-1998 SDM / Air Bag Control Module
- WTB LT1 Water pump Broken/Used or NEW
- FS: Black 1996 PS Inside Door Panel...
- F/S 1 3/4" Stainless Steel Headers LT1 LT4
- Chrome C4 sawblades with LTPWS sensors in So Cal $500
- FS: RD Racing Cross-Frame (X-Brace) never used
- WTB LT4 fuel rails
- F/s Hooker Headers Lt1 Lt4 Ceramic Coated
- Complete Cat Back 96 Corvette
- Dana 36 Rear Complete
- Wtb: C4 Front Spindles.
- Some good C4 Parts F/S
- F/S catback(sort of) w/stainless mufflers
- F/S:B&B resonator 3" in/out
- WTB Lower Shift Boot { Rubber One } ZF-6
- FS: C5 front Calipers/adapter brackets>>
- WTB:95% Plus Condition Rear Calipers for J55
- WTB Mounting braces for alternator-A/C
- WTB: Rt. Side Dash A/C Vent Assy' a 95'
- Applause for forum vendor Vette2Vette
- Parts Discounts?
- F/S Stock 1989 oil cooler sandwich adaptor.
- 1993 Targa Top For Sale
- Corvette Recycling E-Brake Handle Sale
- WTB Stock LT1 catback 92-96
- F/S Vigilante convertor
- F/S Stock air box filter and K&N filter with breathles open top
- WTB LT1 timing cover from 1995 Corvette
- WTB: 1.6 Rockers Self-Aligning 3/8
- WTB: Rear speaker grills for a 91' Coupe
- WTB: MAP sensor and plenum bracket
- ZR1 parts F/S
- FS - 93 3 pc Front Spoiler & Trunk Plastic
- Passive Entry Module
- WTB: FPR & Stock Valve Covers
- WTB/ '94 Radio receiver and abs module
- F/S (2) 1990 ZR-1 rims 11" inch
- wtB: Goodyear F1 Tires - 19" Rear 18" fronts.
- 1990-1996 C4 LT1 LT4 Corvette Complete Front Suspension! Rare Setup!
- 1984-1996 C4 ZR1 LT4 Collector 17" Wheels and Tires! OEM
- WTB EGR valve solenoid for 84 w/Auto Trans
- WTB C4 6 Speed Transmission Case/Housing!
- WTB,1991 ZR-1 right rear wheel...................
- WTB: 86 A/C bolt
- WTB good front hubs for a 90
- SLP Pipes
- WTB Plastic piece that computer sets on 1996
- 1984 power mirror rocker switch. L-R,center off
- Cleaning Out Garage
- Fs '96 Style Front Bumper Nose Cone
- 26k miles- 113 heads, Tpi, 2kmiles injectors..
- msd opti for 93
- I need 1 injector clip
- FS-Service manuals 94 and 95
- Wtb C4 Jack
- Wanted: Air pump (smog pump) from LT1
- Wanted Cold Start Injector assemby
- Slp Intake F/s
- Firestone Wide Ovals For Sale
- FS Right Front Park/Turn Lamp 84-90
- Wanted power antenna bezel 85
- Misc 85 parts
- Wanted: fuel bib - fits around gas fill
- WTB: 1993 Corvette 700R4
- F/S RANDOM TECHNOLOGY HIGH FLOW catalytic converters LT1 LT4
- F/S SLP Headers LT1 LT4
- F/S: Set of 17x9.5 ZR-1 wheels with Kumho V710's
- F/S B&B Exhaust Pipes LT1 LT4
- F/S: Harness Bar + 5 point harness for C4
- F/S: Reese Shadow II hitch for C4
- F/S SVO #30 injectors
- needed asap driver side headlight assembly!!!
- FS- Engine Load Leveler
- FS- Mityvac 6820
- FS-Motive Power Bleeder
- Need 84 power steering bracket asap! help!
- Free Mufflers for 84 and 96
- 87 TPI parts for sale
- FS (NM): 0 Bal 400 hp Al/clutch
- 2 new Vredestein tire 315/35/17
- WTB 1985-1987 A/C Compressor Bracket
- f/s black targa top
- WTS: 3" B&B Triflow Mufflers (Georgia)
- WTB/Stock Exhaust Manifolds/88 TPI...
- 96 Wheels and tires
- FS: Brand new Mcleod Slave Cylinder for T56 transmission
- Tire Sale!!! Over 15 Brands To Choose From
- 87 camaro 305 TPI parts for sale
- For Sale: RD Racing X-Brace - BRAND NEW!
- FS: Fuel rail/Injector cover hold down bolts
- FS: Proform Valve Cover Breathers - black anodized, Bowtie emblem
- FREE: Console frame, Instrument Panel frame, HVAC ducting - off my 96'
- FS: I/P lower trim panel off my 96' (the panel right above your shins)
- FREE: Console side trim carpet off my 96'
- F/SLT1 Waterpump
- FS: Passenger side airbag off my 96'
- F/s Lt1 Meziere Water Pump
- 1989-1996 C4 Corvette Blue Tint Removable Glass Top!
- 1984-1996 C4 Corvette Collectors Edition Black Seats!
- F/S QTP Electronic Exhaust Cutout Controller
- WTB Ball joints
- WTB 8 way L & R power seat switches for 87
- FS: ZR1 GM Service Manual 1990-3
- F/S 4L60E and convertor
- F/s Tpis Longtube Headers
- WTB power antenna
- All Corvette Car Covers 15% Off!
- NOS Corvette Pump To Gear Power Steering Hose, 1988-1990
- WTB: 90-96 Green or Clear Targa Top
