Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
DR questions??
Old Apr 7, 2005 | 12:04 AM
Jserman's Avatar
Jserman
Default DR questions??
I have check this forum and since I haven't found what I wanted I figured I would ask..
I have a 01 C5 with the stock wheels.. my plan is to upgrade the wheels and use my stock for drag racing...
What type of DR's are you guys running.. I want to know name brand...width..where you go them... do you like them/hate them.. everything...and is any one running slicks when the race and the same questions apply..
Old Apr 7, 2005 | 07:30 AM
C5 CU's Avatar
C5 CU
BFG 295/18 will fit your stock wheels, they are a popular DR. They can be purchased from Discount Tire....good luck.
Old Apr 7, 2005 | 08:36 AM
Special K's Avatar
Special K
I have BFG's and like them. For you I think slicks are over kill and you would have to run 16" wheels. I don't think they make them in 17" or 18" but other guys will jump in here and you'll get plenty of info.
Bob
Old Apr 7, 2005 | 09:15 AM
Jserman's Avatar
Jserman
are you guys just running the Drag Radial Comp T/A or is anyone running the g-Force T/A Drag Radial.. I was just wondering the difference...
Old Apr 8, 2005 | 10:06 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
are you guys just running the Drag Radial Comp T/A or is anyone running the .. I was just wondering the difference...
Running the g-Force T/A Drag Radial (tread pattern is different)
in a 275/35/18 on the 00' vert. 1.72 60' nice and will fit on OEM wheels
Running the g-Force T/A Drag Radial in a 345/30/18 on the 97'. 1.52 60'
both have this tread pattern and hook like a ****
Old Apr 8, 2005 | 10:24 AM
bernrex's Avatar
bernrex
Which hooks better ... the Comp T/A ...or your G/Force T/A DR ?
Old Apr 8, 2005 | 10:33 AM
Cruise-In V Veteran
NCM Ambassador
I have not used the Comp TA, but folks who have liked either. Maybe someone will chime in and be able to compare both on the same car
To DR questions??
